the Sun Audio Sv-pm200
Integrated amp which based on sv power amp
Japanese designed and engineering , offering a warm and authentic sound that audiophiles appreciate.
Able to use EL34 , should be able to use 6L6/EL37/KT66 tubes
Power output 4.5w sound not a lot but Whether you're speaker powering , like LS3/5a or Lowther , Tannoy speakers, the Sv-pm200 should bring out the full-bodied range of your audio content.
Come with Japanese el 34 , and EH 6sn7 and gz34
All point to point
All Japanese made tamura tamradio transformer
100V come with Tortech Isolation transformer SD100-1010
Amp Serviced and upgraded the coupling cap to the vintage westcap ( oil )
more information https://www2.big.or.jp/~sunaudio/sv/svpm200_e.html
### Vincent Audio SV-200 (Commonly Referenced Model)
Users and reviewers praise its sound quality for delivering rich, warm midrange, detailed highs, full bass, and surprising headroom despite 25W output—handling dynamics well across jazz, vocals, and rock without strain. The build quality is highlighted as compact, robust, and visually appealing, with quality accessories (remote, cables), smooth controls, and a glowing tube display.
Reliability appears strong based on mentions of dead-quiet operation (no floor noise), volume memory, and consistent performance post-burn-in, though long-term data is limited.
Strengths:
- Bigger, detailed soundstage than expected for size/power.
- Versatile inputs (analog RCA, digital optical/coax) with built-in DAC for high-res formats.
- Hybrid design combines tube warmth with solid-state control.
Weaknesses: None explicitly noted in results; minor setup quirks like removing shipping plugs.
Overall reputation: Highly recommended as a value-packed, portable high-end starter amp for small spaces, exceeding expectations in sound and design.
For the Sun Audio SV-PM200, seek dedicated forums like AudioKarma or YouTube comments, as current results lack substantive user opinions.
### Price Range and Condition Variations
- Used/restored condition: AUD 1,400 (HK$8,000 equivalent), for a fully restored unit with verified performance, good cosmetics, Tamura transformers, and features like 4.5W x2 EL34 triode output.
- New condition: No recent listings found; likely rare and potentially 20–50% higher (AUD 1,700–2,400 estimated conservatively) if available directly from Japanese makers, though unconfirmed in data.
- Prices vary significantly by condition: pristine or recently restored units command premiums, while untested or fair-condition examples could drop to AUD 1,000–1,300.
### Key Factors Affecting Value
- Restoration status: Listings emphasize full restoration, tube replacements, and oscilloscope testing, adding 20–30% value.
- Components and specs: Premium Tamura transformers, Sun Audio capacitors, and triode EL34/6SN7/5AR4 tubes boost appeal for audiophiles.
- Condition and cosmetics: "Good cosmetic conditions" directly noted; wear reduces value.
- Market scarcity: Sparse global used listings on platforms like HifiShark indicate low supply, supporting stable pricing for this single-ended tube amp.
- Currency/location: HK listing reflects Asian market; Australian buyers may pay 10–15% more for import/shipping.
- Date relevance: Data from ongoing used markets as of 2026 shows no major price shifts.
These estimates use conservative conversions and prioritize the sole concrete listing, as broader data is limited. Monitor sites like HifiShark for real-time fluctuations.
