nbn upgrade from FTTN/FTTC to FTTP
Going to chat to Superloop if I can ever get through as higher than 600 is rarely seen
  • Replies 141
  • Views 9.7k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Well I expected the worst as you do with these things, but it all went swimmingly.   Turned up on time, no conduit problems, pit was full of water but that was quickly solved, and the instal
  • I upgraded to FTTP about 18 months ago, the first techs came and found an issue with the conduit, a week later a second crew came and rectified the issue and did the connection, it's been rock solid s
  • Jakeyb77_Redux
    Jakeyb77_Redux
    So a guy came last Saturday and said that the copper in my conduit was too tight to pull the fibre through and would need civil remediation. He wasn’t wrong, the cable wasn’t going anywhere.  Som
Nothing wrong with that. 👍
Check your modem/router is capable of 1000Mbps down. I had a hardware limitation at 750Mbps when I first upgraded. Turned out it was the firewall (software) in my setup that was throttling the speed.
48 minutes ago, Jakeyb77_Redux said:
If someone genuinely asked me if the picture improved on my LG Oled I couldn’t tell.
 The bandwidth required is less than what you have on 50 mbps, so I would not expect it.
26 minutes ago, Marc said:
That sounds like you need to investigate your WiFi hardware and signal throughout the home.
Yes, I added a "wifi extender" in my new place as all the kitchen metalwork, fridge stove, microwave (worse when it was running) made my living room measure as being about 10x further away from the wifi source than it actually is.
Many Wifi routers pump out both 2.4GHz and 5GHz networks, the slower one has better range. Some phones (mostly the ones that start with "i") don't play nicely when swapping between them.
Good point.  I expended both mine.
You can also increase the "width" of the channel and the power.
On 12/3/2024 at 12:09 PM, Snoopy8 said:
Had a seamless FTTC to FTTP free upgrade through Superloop completed today.  A technician did the outside work 2 weeks ago.  The inside done in less than 1 hour, made easy by pulling out the old HFC cable (pre FTTC).  Switchover done by Superloop in 15 mins after they received notification from NBN.
Not sure if people are aware, but NBN could be offering up to five times the speed at the end of the year for no extra cost!
https://theconversation.com/nbn-upgrade-what-a-free-speed-increase-for-fast-broadband-plans-would-mean-for-consumers-and-retailers-225168
It was mentioned in The Age that this free speed upgrade will apply to FTTP and HFC users.  So, another reason to take advantage of the FTTP upgrade from your ISP.
A mate text me today to say he just got Superloop.    I had never heard of it.  1000 down and 50 up.
Regards Cazzesman
Regards Cazzesman
Yes.
Superloop and Leaptel are the new competitors to ABB.
Local support and ownership with great speeds and stability.
Regards Cazzesman
I use Superloop. Good price too. The creepy guy in the ad nearly put me off
I’ve been with Optusnet so long and being a silly lad 20 years ago, I have the Optusnet.com.au email.
That email has me all around the world, so I need a work around to keep the email address and get onto providers such as Superloop etc.
I’m open to suggestions.
Regards Cazzesman
Went from ABB (whose support is superb, but at a premium) to Superloop.  Had a few interactions and their support is good.
Am afraid you will need to get a Google account or something and run your Optus in parallel for a few months until you feel confident that you can ditch it.
Mine with the “i” in it swaps ok, which is just as well, because the wifi antenna in it is awful. My bedroom is 5m away from the router, with one stud wall between (less really, if the door is open), and I barely get a signal on 5GHz.
Edited by Flash
Today, I am getting an upgrade to FTTP for my NBN. However, the technician who came to my place refused to lift the roof tiles or enter the cavity because he said he doesn't fit in. I had to do it myself to proceed with the upgrade. It was useful to have a smaller build in this situation. There is one pit in front of my house and another pit at the main road.
I see a green optical cable and several black optical cables in these pits.
Hahaha, that's a good excuse for the "tech" who doesn't like dusty, cramped spaces (aka a slack b*st*rd). But I reckon NBN Co would have something to say about that if you queried why they'd use contractor that wasn't fit to do the job. What about poor old bungers like me, I'd be on the phone quick smart. Although you have to weigh up the inevitable delay against just getting it done though.
Yeh that’s awful customer service. I used to be a sparky, and also hated lifting roof tiles, but you still did it. The main reason was getting them back in place properly. It was even worse if they were tied to battens. You’re bringing back bad memories from a life long past! 😖🤣
After upgrading to FTTP, my internet has become more stable (especially in the evening), which was certainly worth it with the current no-cost promotion. I'm glad I made the upgrade.
  • Author
what about a colour bond roof?   😀
You get to see all sorts of environments,   Removed a cover and there mouse droppings everywhere,  or spiders!    Sometimes I spend 20-40mins removing the stuff that the client used for storage as it’s supposed to be path of access to 1.2 tonne of machinery.   Gotta do what you have to do to get the job done.
Edited by Addicted to music
That’s why I left domestic contracting soon after I finished my apprenticeship, and went to commercial, then mining and construction. Crawling around in roofs, and under floors had knobs on it. 🤣
On 15/03/2024 at 9:32 AM, Jakeyb77_Redux said:
Wifi is all good. Brand new Eero mesh. I came from a Google mesh. Most of the time I’m in the lounge next to the modem and it speed tests ok.
Maybe my phone is glitchy
Try it at some godawful time when nobody should be awake - could be your contention ratio (as in others using the bandwidth at the same time)
Feeling a bit green with envy from reading about everyone that's had a successful FTTP upgrade.
My first technician attendance appointment in December was cancelled the night beforehand and re-scheduled till January.
The January appointment was cancelled and re-scheduled till Feb. The Feb appointment was cancelled and re-scheduled till today.
And yes, you guessed it. After waiting around all afternoon ( appt 1-5pm) at 5:30pm I get a notification from my provider that NBNCo have re-scheduled me till the end of April.
Thanks NBNCo, I would rate your Customer Service as ZERO stars!
If they don't get to you on the day your booked for......you go back on to the end of the queue.
WTF???
"Not happy Jan"
The way it is going I will be fortunate if the FTTP upgrade to my premises is available in my lifetime.
I contacted AB and they said they have absolutely no idea whatsoever when ( IF ) the upgrade may be available.
OTOH my 100/20 plan works quite well so I am just going to forget about the whole thing.
Fingers crossed that the situation improves and you get the upgrade - I have found that nbn can be very random with estimates and then suddenly they're ready to go
  • Author
The time has finally come.  Was contacted by ABB, date set for 3/5/24.   An hr after that call,  contractors were at the door around 5:30pm say they need access to the entry point of the house.  Then they came back and said it’s not accessible from the pit and will try another entry in the morning as it was getting dark.  The boss said they completed there end of the task today.
So have they just installed the casing and pipework or have they done the conduit to your nearest pit?
Great news that you're seeing some progress!!!
Edited by purpleninja
My FTTP connection is scheduled for later this week and I have a two storey home, what are my chances of convincing the technician to install the internal connection box on the first floor near my modem? Anyone else had this done or will it just be installed in the garage on the ground level?
