Home Theatre / Media Room Build - Covid Project
Just curious as to what are the purpose of those bipoles mounted in between your fronts and your surrounds ??
  • Replies 32
  • Views 2.1k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Finished Room (…well almost) lol The room has turned out really great and is versatile to manage various needs. When in pure HT mode the room and systems deliver an outstanding immersiv
  • I decided to source a few low cost foam elements and installed them as bass traps and absorption panels to complete the acoustic treatment. Below is the final fully treated room.
  • Stage 3: Final Finishes, Fit Out   Carpet and final coat paint finishes were supplied by tradesmen including all lights & power fit off. The main wall for the screen location was painte
Well done.  Lock-downs are a breeze with a decent home theatre!
  • Author
yeah, they operate as L&R surround (centre fronts) with the 7.1.4 end game in mind.
They're THX certified and sound is so spacious they work even though forward of the seating position.
Never seen bipoles used as Front Wides. Wouldn't direct radiating speakers be better as the bipoles will be sending sound forwards to bounce off the front of the room and muddy the front soundfield ?
great write up and project - thanks for sharing.
Well done and have fun tinkering with Audyssey.
Once I got my manual adjustments sorted on a flat curve base that I did at 2.00am in the morning with all potential noise making appliances off, I am locked in and very happy.
Others next door and your housemates not bothered by you enjoying the room with all the treatments?
  • Author
Clarification, they're Di-poles so apology for any confusion. My idea was to future proof the system with THX / Atmos capability if ever I wanted to go there and this new Magnat Cinema Ultra pair I got for a song. I can easily switch these into being the main L&R surround centre's by simply changing the channel output at the main speaker matrix wall plate, albeit acknowledging that they would be a slightly forward of the main seating position. It's just the tweeters which are out-of-phase, the bass driver faces the centre of the room.  It may not be a technically correct application for di-poles but I find that they deliver extra depth and movement of sound (e.g. helicopters, planes, cars etc) so am happy with the current set up.   (correction: end game is 9.1.4 set up not 7.1.4)
But Atmos (and all 3d sound) calls for direct radiating speakers and dipoles are not recommended by Dolby. Very hard for speakers to place a sound in a 3d location if the speaker is firing off in different directions. My own testing in my room with bipoles certainly backs that up.
