Cam's System
9 hours ago, SETSergio said:
One per side Cam?
Nah...should be able to fit both kids in the one box...
  • 1 month later...
  • Replies 147
  • Views 26.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • caminperth
    caminperth
    After a while away, I'm getting back into this stuff. Dragged out the LM monos and Elrog/Emission Labs tube combination this morning for some fun. Different to the 833/KT150 combination, though need t
  • caminperth
    caminperth
    It's been a while since last update. There have been a few iterations of Line Magnetic gear coming through to test & run in. Some photos below..   LM-812 Iconic speakers running from LM-
  • caminperth
    caminperth
    Everything now wired up and tested. Quite happy with the result. It weighs a ton and is rock solid - no movement, though expected. The threaded rod could hold up a couple of ton if needed... Sent f
  • Author
On 9/2/2017 at 9:15 PM, SETSergio said:
Best of luck with that...... my sincere empathy. :thumb:
Now one per side. Has evened things out nicely.
MiniDSP on the way for a bit of EQ and that’ll be all the bass I’ll ever need!
Winner, winner....chicken dinner.....nice work Cam:thumb:
  • 1 month later...
  • Author
On ‎11‎/‎05‎/‎2017 at 2:27 PM, caminperth said:
I just can't help myself.. had to try out some 845 valve goodness. When someone told me that a single 845 per side wouldn't work, I thought I should try two... :party
They are currently in getting the once over by a local tech. Next will be to source some 845B valves.
They are Antique Sound Labs AQ1009 845 DHT mono blocks. There isn't too much on the net about these things so I'll start a thread in the Amps section of the forum to collect the info I've found so far..
After extended repairs they are back and sounding much better. Photos to come once setup properly.
  • Author
  • Author
Some more changes...
Both sub boxes in place, now running through a minidsp (which I’m still tweaking), 845’s glowing and a change of cart. Sounding the best it has so far.
  • 2 months later...
  • Author
Rearranged the gear, dressed/laid out the cabling to separate power and source cables, added a PS Audio P10 and some entry level power cables. The difference is quite staggering - makes me think that I should've bought the P10 as the first piece of kit, could have saved me turning over a lot of gear! Everything is a lot clearer..
I primarily bought it to step the voltage down to a steady 220V for the power amps, however reducing the line distortion from 5% to 0.1% has made quite a difference. Much better than the Thor unit I tried previously. I'm guessing that a regenerator will actually change the signal in, whilst a variable step down transformer won't make much of a difference.
Everything set and waiting for the new speakers to arrive. They've been on order for over 3 months now so I hope they are worth the wait!
  • 3 weeks later...
  • Author
After nearly 4 months, they have landed!
Awesome Cam!  You must be over the moon:party
Now for the break in where it just keeps getting better and better:thumb:
Congratulations!!!
Congratulations!!!
GTG?
  • Author
Congratulations!!!
They certainly look the business - even taller with the plinths on. Break in is taking a while due to being busy at work and a full weekend. Travelling next week as well so will be delayed by a couple more weeks. Given they took so long to get here I suppose it won't make too much difference to wait a little longer...
On 21/02/2018 at 7:45 PM, Mendes said:
GTG?
Break in first - but would have to be very small. Only a tiny room and couch..
Edited by caminperth
Hi Cam
Break-in is easy mate, just connect them up to an old AVR or amp and run them 24/7 at low volume with a tuner.  You can put them face to face, throw a blanket over them and leave them running all week.
I do this in the workshop with all my speakers.
  • Author
13 hours ago, Peter_F said:
Hi Cam
Roger that - unfortunately don't have the room to do it. It's ok though, they do run them for 600hrs (reportedly) at the factory first so shouldn't take too long.
  • 10 months later...
  • Author
A while since the last update.
Have moved house, allowing for a larger room and better view. [emoji106]
I have gone through an amplification journey. Gold Note, Yamaha and now onto Primaluna. The HP integrated is currently in for a service, but luckily I held onto the preamp and little class a DIY creation - both of which are doing a good job.
Also added an SVS SB16 which is running in nicely.
Some pics below.
Some pics below.
86322a8a6681f7d729e7f3921dec788b.jpg&key=ee4afe2d570cf2f4f0bb89175a7cafd6e6cf78340a05fbd9eb77848d0f43e329
f09d723d703670b86a3703dd87601bcb.jpg&key=30c007d87768d88c605bc17e2fa5c25453aef62dbce7afff7d6b122ffb2142e8
7a94838204e57590210005e47376a3c6.jpg&key=cd47f3f08b6129f05a5d42b7b85e197fdbf12f9b9b13fe40aed1eddcee2b12ee
Thats a good looking setup with a ripper view!!
New house look stunning Cam. If I can make a suggestion : As the Lp12 is sitting on a heavy unit with a lot of other equipment on it a Trampolin base should yield great improvements.
  • Author
Thanks Oz. It actually has one of these - any good?
Looks fantastic Cam.
The imaging and soundstage significantly different to your previous room?
  • Author
Cheers. Hard to tell at the moment as I’m still playing with valves and waiting for my the HP to come back. Initial thoughts are yes, but will know once the HP is in and settled with some nice front end valves to match the KT150’s and Zu’s.
What are the rectifiers and two tall centre valves in the Dialogue preamp, Cam?
  • Author
Rectifiers are Phillips and the tall 12AU7's are Brimar long plates. The Brimar's seem to work with smaller power amps, however different valves match different amps I've found.
Hi Cam , I am told the Cetch subchassis is very good however I am talking about a 'device' that replaces the baseboard of the Lp12 with one constructed of aluminium with a foot in each corner that has a suspension system built into it to isolate the turntable from what ever it is sitting on.  Link :  https://www.linn.co.uk/sources/turntables/baseboards
Edited by Ozcall
  • Author
Ahhh - understood. Thanks for the link. Could be worth a look, though I don't seem to get much "feedback" type noise.
One thing I have noticed is background noise at high volume when nothing is playing - I'm guessing that one of the mag-lev collars would possible solve this?
  • 9 months later...
  • Author
So there have been a few changes in between, but this has landed and is impressing straight out of the box..
D76846D9-B0D6-4AD6-A26C-BBFD65E1C328.thumb.jpeg.3e97e131ad95ca3dab93ee2b29935188.jpeg69D0B628-32F3-43C1-9451-B46FFFBB34B3.thumb.jpeg.3097beba08c99954f8844415a706e21d.jpeg989F2350-34B0-418C-A9D9-9086A640733A.thumb.jpeg.f5dfa7d67fe4b4a84537d6c7e7cdfefe.jpegAEC90C7F-0403-440F-9F72-D04652D74E5C.thumb.jpeg.614dc6ab4ab03be399519f3a97be4ddb.jpeg
  • Author
It was heavy!
