bones78 Posted August 8, 2023 Share Posted August 8, 2023 Item Condition: Excellent Shipping Options: Pickup available but audition is not available. Suburb or Town: Davoren Park State: SA Payment Method: Cash on Pickup Reason for selling: Downgraded/Room changed back to proper bedroom Further Information: Hi, I am selling my 5.1 system as I have as I have turned my bedroom/home theater room back into a proper bedroom again, so unfortunately they have to go -Adelaide Speakers Fronts/Stereo Woodfox 823SQTL - Large 3-way bookshelf speakers low sheen black, 8 ohms, 500h x 240w x 310d. - https://www.adelaidespeakers.com/woodfox-bookshelf.html Specs from website : Power Handling: 140 wrms Nominal Impedance: 8 ohms Frequency Response: 41 -- 30,000 Hertz /-2dB (with dynamic output right up to 40,000 Hertz) Sensitivity: 90.5 dB 1w/1m Drivers: 8 inch long throw quality reinforced cone driver; SB Acoustics 5 inch midrange; wave guide tweeter crossing over at 2500Hz. Description: This is a unique and super detailed 3-way bookshelf speaker similar to our 863 Summoner but in a large bookshelf cabinet using the same high quality drivers. The superb micro detail of the wave guide driver lets you hear exactly what is going on through its whole range. The transmission line bass and midrange, have a very complimentary, clean, level, non resonant response when controlled by our highly tuned crossover. This 3-way is a large and uncompromising, full range, reliable and powerful speaker for all uses at an irresistible price. Purchased November 2020 and still under warranty until Nov 2025 -Adelaide Speakers Centre 263SQ - Trio 3-way 5 driver centre channel, low sheen Black, 8 ohms, 900w x 200h x 310d. - https://www.adelaidespeakers.com/centre-channels.html Specs from website : Power Handling: 180 wrms (@ 60Hz plus) Nominal Impedance: 8 ohms Frequency Response: 44 -- 30,000 Hertz /-2dB Sensitivity: 91dB 1w/1m Drivers: 2 x 165 mm SB Acoustics long throw bass drivers and 2 x 120 mm midrange; wave guide tweeter Description: This is a larger full range high end 3-way centre; powerful bass and clear voice production. Purchased November 2020 and still under warranty until Nov 2025 -SVS PB1000 Pro 12 inch Subwoofer - https://www.svsound.com.au/products/pb-1000-pro Purchased Dec 2021 and still under warranty until Dec 2026 ( comes with port plugs ) -Dali Zensor 1 Bookshelf speakers used as Rears - https://www.hifireport.com/dali-zensor-1-review/?expand_article=1 -Yamaha RX-V583 Receiver - https://au.yamaha.com/en/products/audio_visual/av_receivers_amps/rx-v583/index.html Link to comment Share on other sites More sharing options...
Sonica Posted August 9, 2023 Share Posted August 9, 2023 Hi Bones, your Yamaha receiver has the capability to integrate all speakers and subwoofer. Do you know if that could be achieved with an common integrate amplifier? Cheers Link to comment Share on other sites More sharing options...
bones78 Posted August 9, 2023 Author Share Posted August 9, 2023 13 minutes ago, Sonica said: Hi Bones, your Yamaha receiver has the capability to integrate all speakers and subwoofer. Do you know if that could be achieved with an common integrate amplifier? Cheers Hi Sonica, I honestly don't know the capabilities of a common integrate amplifier having never owned one or looked into getting one, I would have to do some research to know for sure. Sorry I couldn't help Link to comment Share on other sites More sharing options...
Sonica Posted August 9, 2023 Share Posted August 9, 2023 Hi Bones, thank you for your honest answer. Good luck with the sale! Link to comment Share on other sites More sharing options...
thorpef1 Posted August 10, 2023 Share Posted August 10, 2023 19 hours ago, Sonica said: Hi Bones, your Yamaha receiver has the capability to integrate all speakers and subwoofer. Do you know if that could be achieved with an common integrate amplifier? Cheers Integrated amplifiers are usually stereo, so you will be able to connect 2 speakers (left and right) and probably the subwoofer, you would be short the 2 rear speakers and the center channel if you were to use a integrated amplifier instead of the receiver. Link to comment Share on other sites More sharing options...
Sonica Posted August 10, 2023 Share Posted August 10, 2023 Yes, correct. Thank you for elucidating. Link to comment Share on other sites More sharing options...
Volunteer sir sanders zingmore Posted August 10, 2023 Volunteer Share Posted August 10, 2023 This advertisement has been withdrawn or the offer has expired. Link to comment Share on other sites More sharing options...
