pasic007 system
11 hours ago, genkifd said:
Damn i threw away my 389 empty bottles
time to upgrade to Grange, sounds better.
  • Replies 86
  • Views 8.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Lumin T2 vs my old Node 2i initially it was hard to tell difference as I would need to get up walk 3m to change input.    So I moved the whole rack.... next to me lol.    Comparing
  • I think I'm done for now.    Edit.. Maybe just diffuser. Lol
  • Took these bad boys out of storage. Only issue is I don't have a amp to drive them.  Three years have gone past soooo quick!   Think i need to start only fans page to fund rest of the system
  • Author
I've had few requests I'm tweaking design a little then ill do a small batch run.  Ill do them free of charge there isnt much to it.  If people really like them, small donation can be made, this will be put towards more roles of filament.
  • Author
Ive seen those, price of a nice speaker cable !  Im sure Chanh would have few of those too haha
The year of release is also critical. So far - I have found "2010" vintage sounded best.
Pls have my name in the list too. ?
Hmmmm.... The good old days prior COVID.... Life is much tougher in the last 12-Months.... Have only managed with much more affordable white variety or cable riser..... ?
Edited by Chanh
  • Author
When i hear "white" along with wine i think of these cable risers. I hope that's not the case Chanh  haha
Well done, headphones to that, you don’t muck about .
  • Author
Been busy last few days.
I've finally finished off the Lumin power supply cover / plug.
Since I've installed Gieseler LPS I've had big hole where I removed the male C14  AC plug.
I've made up the plug that screws into same location and makes use of XLR connection to feed clean power to Lumin.  I couldn't finish off the install I lent out my special screw driver kit :(
To me this looks better than what is currently available on the market.
Tomorrow I'll try get some more cable spreaders printed.
  • Author
How Lumin T2 should come out the factory :)
Edited by Pasic007
Uh one pic is upside down.
  • Author
Comparing the two, there was very subtle difference, I don't have audiophile ears just equipment.  But when I played "The final thing on my mind" I had to double check make sure everything was ok. Node's sound stage was small one channel also felt as it was turned down..compared to Lumin! Such clear difference.  Some other songs I dont think I could tell, as they weren't so obvious.
Node 2i is such a damn good streamer and dac, from my experience I couldn't recommend it high enough.
Is the Lumin worth 6x more, well yes and no. If it wasn't for Lumin I wouldn't have know that Node 2i sounded broken on that specific track.
Down the road I go to standalone lumin streamer and more expensive dac. How deep is the rabbit hole ?
Speaker cable i was using wasPeakaudio UK standard, no idea what it is???. Was in my girlfriend box of cables I needed something longer for moving the rack.
  • Author
Also made some rca caps for Supratek.
  • Author
Bit of fun.    Testing two different streamers and no preamp.  Same same but different.
Thats sounding great even through you tube. Tubes and Sonus Faber, but it sounds very lively and engaging.
Does it sound like that in the room.
Gonna get that album, i liked it.
  • 3 months later...
  • Author
I added rythmik sub few days ago, i took some reading and when i took  REW readings with sub and no sub. The sub made things worse...  In my mind it sounded better because more presence of bass..
Anyways i repositioned sub, flicked few other settings, adjusted the Low pass and damping and it came the measurements looks so much better.
i guess there is 2-5db more of bass, and i removed some of the problem areas.
At this stage PEQ is turned off. I will leave that for another weekend.
  • Author
Unless I'm missing something obvious this doesn't look good as bass appears to decline quite rapidly from about 110hz without or with the subwoofer as currently positioned and configured.
Edited by Satanica
  • Author
I dont think its too bad, you can only do what you can do with the room you have lol.   Here is full measurement.
Mic is stationary in single position, if i was to move it around i could probably get better average? But i prefer to have it stationary to be more consistent.
2 hours ago, Pasic007 said:
I don't think its too bad, you can only do what you can do with the room you have lol.   Here is full measurement.
Sorry - I'm afraid I agree with S:
Your sub seems to be doing absolutely nothing!!??  :o
And btw:
  1. I don't think the room has much to do with that bass response.
  2. yes, absolutely keep the measurement mic stationary - basically, where your ears are located.
Andy
Something not right there... the rythmiks should give clean bass down to at least 30hz...
If the system is currently sounding good , then I suspect it is something to do with the REW software settings.
I'd've thought at least 25Hz, t.  :thumb:
(Unless it's a huuuuge room.)
Andy
  • Author
It is turned right down.  I thought this was normal for "musical" subs lol My previous KRK 12" SHO was tooo much..
Placement of the sub is right next to the seating postion as  my preamp is close to seating postion.. will change .
It does sound good but yeah need to look more into it.  ta for feed back..
  • Author
Green Sub Off
Blue Sub on
Orange Sub turned up
Im not familiar with how subs look on REW . I should get my old KRK out see how that looks.
Hrmm still something still seems odd with measurements.  Are you running the stradivaris full range and just augmenting the subs in or using the rythmik plate amps to run a high pass filter on the speakers?
Below is freq sweep of strads from stereophile. Should have strong bass response to 30hz!
As tuyen posted ... if you have Strads then you should be seeing a graph like the below - with subs off!
Your graph:
Green Sub Off
Blue Sub on
IE. green - with subs off - is very different.
Are you using a calibration file with your mic?
Try turning the sub volume up a lot - so that when you do a sweep ... 30Hz is at the same volume reading as 120Hz.
Andy
  • Author
Full range, in a non ideal room powered by Tubes hence i got the sub to experiment.  I knew  F12SE would be too small, but i wanted to test Rythmik out before i commit to pair of 15s.
My room is not that big but its open floorspace with another lounge and kitchen.
I just had realestate agent over today, i'm either knocking down and building bigger house with dedicated room or selling and getting something more ideal.. :)
Sounds like fun..! Nothing beat a dedicated room… From my experience, it brought average electronics like mine to whole new level. I listened to many mega $$ electronics in an average room and they sounded very average to majority…!
Having said that, you could take on my residency… All hard works had been invested….! I can move the boss and her immediate family member to Dailketh in trade of new speakers…! Currently dreaming Marten CS2! 😍😵💫🥺😫
Edited by AccuMagi
