I currently use the Moon Audio - Silver Dragon 3.5 mil single end cable into IEM Unique Melody Miracles.
My Fiio M11 DAP has 2.5mil and 4.4mil Balanced inputs.      Anyone recommend a 2.5mil Balanced headphone Cable with 2 pin ends to try out at a reasonable price.   Under the $100 mark.   Not interested in paying the $350+ for Moon Audio Cable.
Regards Cazzesman
IMO, 4.4mm is the better connector. Could look into the Dunu DUW-02, comes in 2-pin and MMCX and allows you to quickly swap connectors. Aliexpress with coupons, or wait for a sale, and it should come around the $100 mark.
  On 23/09/2020 at 11:42 AM, Decky said:
1 mil = 1/1000 inch
mil and mm are not the same thing
Expand
We all know what he is talking about though ;)
Try AliExpress. Jump on the Head-Fi thread about chifi cables, and you'll find a decent choice.
Expand
I am so happy to be in a company of so many people with telepathic abilities - I cannot count myself as being one of them.
I haven't tried the 2.5 mm version, but I have been using the 4.4 mm mmcx version of this cable for Campfire IEMs:
https://www.ebay.com.au/itm/KBEAR-16-Core-QDC-Interface-Pure-Copper-Cable-2-5-4-4-3-5mm-For-KZ-ZSN-ZS10-Pro/124183487630?_trkparms=ispr%3D1&hash=item1ce9e9a48e:g:RvMAAOSwse1c~25~&amdata=enc%3AAQAFAAACYBaobrjLl8XobRIiIML1V4Imu%2Fn%2BzU5L90Z278x5ickkp2NA0WuhQytmt4dbStg00DWkonrZjRAuRj%2BfbxIZfX2XOacWpuYTbQpQ3bkN3oAqsKM34Xckm3w%2BcM4F1LQhxZed9ywAA1Q%2BHXec1WTNiftDAX5D%2FcF3%2FE1%2FjpKZcUbYuGigEByccOQXIFl6XyBfK82USawa8t6OE0x387ailldMMkQQpROd%2BI95LrnOkWPZ%2BMtc04TT%2BTAafHz0bohO65RRmGgrEnSz10XekAH1ehR1H5wfuby7hckGhctLUPNGuJ7DZAdSc%2BW5vzI80OYqSkpmh90Ok2QEaQnzqPB1h6RMVP7Ru4SxStpys243inZGse6actUA2046J38bE9mSfR7ZuHRPIH35y1LVbmjY83EUnHTm29Pg1G9Dl80Bj%2FDgPN3FO9Lr%2Bv8tOzpGHzro9Rt35recEnXbnIlhxfI3pROUALFjPF8pOvDH6CJ3szGJmbJ%2BcH3XiQYFWac6OeBAdpRs2PdI2kxuGNrvTktar82uq%2FJYn2eKNNsd7Y2IS05iE7bAn2SgQfbtX%2FuzWPkhuK0YzBPQwLajy5VXKSFXaAe0xuZNWbXVFgrdZJrDknsLzOhwNl4sieT%2FTDp6SsqN8laHlqXVzwTXjLzaYnw6tQY1OOyzo4G1rDh27skBLvesVlLDQTuE72WiJGtyvYrc6TvHgYL1GfWCvUPzPEj%2FIhnkV82BVn9raMN%2FcRVDM30d51lU4b%2BVPXt%2B1fE8B07Hfk8We9D%2FPwd5wXfjYpsqcKCJowQIC6q4zpcz9U%2FesA0Q|cksum%3A124183487630da71ef59b1af4ae9aaafde3f121f87e8|ampid%3APL_CLK|clp%3A2334524
Nothing fancy, but quite flexible with no noticeable microphonic effect.
I think the 2 pin version should work for your IEM. I purchased one for a Noble Tux5 which has a recessed socket, and 2 pin connector KBEAR uses sit proud so that didn't work too well at all .... Might be worth have a quick look to be sure.
  • 1 month later...
https://www.linsoul.com/products/linsoul-7n-occ-cable
Ended up buying these Balanced cables with the 4.4 connector.  They arrived today.   Thankfully the cable is not as 'Bright Gold' as they appear in the image.   Fit and finish is excellent.    The .78 2 pin connects fitted perfectly into my Miracles.
First impression via the Fiio M11 pro were very impressive.   Clear and clean presentation with good sound stage.
Very happy with the product, that came at a very exceptable price.
Regards Cazzesman
