Guest DrSK Posted December 12, 2019 Share Posted December 12, 2019 (edited) Precursor to the Soliloquy according to Mr Metaxas. Edited December 12, 2019 by DrSK Link to comment Share on other sites More sharing options...
ferrox168 Posted December 14, 2019 Share Posted December 14, 2019 Atma-sphere MA-1. 8 Link to comment Share on other sites More sharing options...
realysm42 Posted December 20, 2019 Share Posted December 20, 2019 On 05/12/2019 at 9:33 PM, mwhouston said: There has been some likes for this amp build. Just one other image of the inside. What’s the little red parts that sit across the capacitors? 1 Link to comment Share on other sites More sharing options...
930turbo Posted December 20, 2019 Share Posted December 20, 2019 Hi , Just like our fellow forum member Ittaku , I also am into ARC . Never tried any other amp & preamp been loyal since 1988 . Here are my amps 13 Link to comment Share on other sites More sharing options...
mwhouston Posted December 20, 2019 Share Posted December 20, 2019 1 hour ago, realysm42 said: What’s the little red parts that sit across the capacitors? Two names; snubbers or bi-pass. Bi-pass is more correct because snubbers usually have a resistor also. Generally they are same polies - 0.1uf. Large electrolytic caps have some internal noise. The smallest caps help suppress that. Also they provide a better path for the return audio. 3 1 Link to comment Share on other sites More sharing options...
realysm42 Posted December 20, 2019 Share Posted December 20, 2019 12 hours ago, mwhouston said: Two names; snubbers or bi-pass. Bi-pass is more correct because snubbers usually have a resistor also. Generally they are same polies - 0.1uf. Large electrolytic caps have some internal noise. The smallest caps help suppress that. Also they provide a better path for the return audio. That’s interesting, thanks. I’ve got them across the caps of my amps and it was the first time I’d ever seen / noticed them. 1 Link to comment Share on other sites More sharing options...
Yamaha_man Posted December 20, 2019 Share Posted December 20, 2019 (edited) The top is current the bottom is some of the past. Edited December 20, 2019 by Yamaha_man 5 Link to comment Share on other sites More sharing options...
mwhouston Posted December 20, 2019 Share Posted December 20, 2019 10 minutes ago, Yamaha_man said: The top is current the bottom is some of the past. Big HSs on the amps near the speakers. Class A? Link to comment Share on other sites More sharing options...
Ittaku Posted December 20, 2019 Share Posted December 20, 2019 2 minutes ago, mwhouston said: Big HSs on the amps near the speakers. Class A? That's these infamous beasts: Link to comment Share on other sites More sharing options...
Wimbo Posted December 20, 2019 Share Posted December 20, 2019 They are strapped at the back and bolted together at the sides. This is all done by the owner or installer. 5 Link to comment Share on other sites More sharing options...
mwhouston Posted December 21, 2019 Share Posted December 21, 2019 Couldnt see in specs etc if they are Class A or not. Could be AB with a heavy bias thus the big HSs. Link to comment Share on other sites More sharing options...
audiohippo Posted December 21, 2019 Share Posted December 21, 2019 Sexual! 8 2 Link to comment Share on other sites More sharing options...
Batty Posted December 21, 2019 Author Share Posted December 21, 2019 Sorry, can't agree. 2 1 Link to comment Share on other sites More sharing options...
Yamaha_man Posted December 21, 2019 Share Posted December 21, 2019 3 hours ago, mwhouston said: Big HSs on the amps near the speakers. Class A? Here’s some info. https://translate.googleusercontent.com/translate_c?depth=2&hl=en&nv=1&rurl=translate.google.com&sl=ja&sp=nmt4&tl=en&u=https://audio-heritage.jp/KRELL/amp/kas.html&xid=17259,15700021,15700124,15700126,15700149,15700186,15700190,15700201,15700214&usg=ALkJrhjLTR4sBrfO2jNx80OSBOX1szFa6w 1 Link to comment Share on other sites More sharing options...
Guest jakeyb77 Posted December 21, 2019 Share Posted December 21, 2019 On 04/12/2019 at 11:31 PM, mwhouston said: Newly built DIY “Precision” - 300W Holton inspired. I was going to ask how this went after seeing it at your place. Does it do 2ohm loads? Link to comment Share on other sites More sharing options...
mwhouston Posted December 21, 2019 Share Posted December 21, 2019 42 minutes ago, Yamaha_man said: Here’s some info. https://translate.googleusercontent.com/translate_c?depth=2&hl=en&nv=1&rurl=translate.google.com&sl=ja&sp=nmt4&tl=en&u=https://audio-heritage.jp/KRELL/amp/kas.html&xid=17259,15700021,15700124,15700126,15700149,15700186,15700190,15700201,15700214&usg=ALkJrhjLTR4sBrfO2jNx80OSBOX1szFa6w Just as I thought Class A. Dan, an SNA member, built some spectacular Krell monoblocks Class A amps. He brought them over for a listen. As with all his amps they are built with high end components and look stunning. Link to comment Share on other sites More sharing options...
mwhouston Posted December 21, 2019 Share Posted December 21, 2019 52 minutes ago, jakeyb77 said: I was going to ask how this went after seeing it at your place. Does it do 2ohm loads? I’ll ask. Link to comment Share on other sites More sharing options...
mwhouston Posted December 21, 2019 Share Posted December 21, 2019 57 minutes ago, jakeyb77 said: I was going to ask how this went after seeing it at your place. Does it do 2ohm loads? Not design for 2ohm speakers but OK if part of the speaker characteristics dip momentarily into 2ohms. Link to comment Share on other sites More sharing options...
Wimbo Posted December 21, 2019 Share Posted December 21, 2019 (edited) 1 hour ago, mwhouston said: Not design for 2ohm speakers but OK if part of the speaker characteristics dip momentarily into 2ohms. So, not good for Apogee Duettas or Scintillas but fine with any "Normal" speaker that dips into 2 ohm. I have the stereo version and Wow. The control and dynamics of the Gales is very very good. As well, a clear 3D soundstage with presence. Edited December 21, 2019 by Wimbo 1 Link to comment Share on other sites More sharing options...
mwhouston Posted December 21, 2019 Share Posted December 21, 2019 15 minutes ago, Wimbo said: So, not good for Apogee Duettas or Scintillas but fine with any "Normal" speaker that dips into 2 ohm. I have the stereo version and Wow. The control and dynamics of the Gales is very very good. As well, a clear 3D soundstage with presence. Bass, transparency and sound stage. All under control. 1 Link to comment Share on other sites More sharing options...
Willmax Posted July 16, 2020 Share Posted July 16, 2020 (edited) New power amplifiers of the thermionic variety ;-D Edited July 16, 2020 by Willmax 15 1 Link to comment Share on other sites More sharing options...
EddieT Posted July 31, 2020 Share Posted July 31, 2020 On 21/10/2019 at 11:34 PM, Ittaku said: Never really thought of it as pink, that's just how it turned out in the photo. It's red, honest... But it's nice a thick and shaggy for my slate tiled floor. It’s PINK don’t be shy be OUT& PROUD 1 Link to comment Share on other sites More sharing options...
Lochawe Posted July 31, 2020 Share Posted July 31, 2020 Absolare Altius 845 SET monoblocks – system recently reconfigured but still driving my Voxativ field coil 9.87 rear loaded horn speaker system... 13 1 Link to comment Share on other sites More sharing options...
Willmax Posted July 31, 2020 Share Posted July 31, 2020 Ai caramba, those monoblocks look amazing! Link to comment Share on other sites More sharing options...
Lochawe Posted July 31, 2020 Share Posted July 31, 2020 3 minutes ago, Willmax said: Ai caramba, those monoblocks look amazing! They sound even better : ) 1 Link to comment Share on other sites More sharing options...
