Irek Posted April 13, 2019 Share Posted April 13, 2019 First of all cheap bluray players don't have a DAC, so they can work only as a transport. Unless you think about something like $600 Ultra HD Blu-ray Player DP-UB820. So, the answer is $600 bluray player with whatever high resolution files cannot compete with $2000 CDP. $300 BRP + $1000 DAC still is worst than $2000 CDP. $1000 DAC with asynchronous usb connection to laptop will get close. CD quality is actually very good, I have a problem to distinguish the difference between CD and high res files. Have a look at http://www.2l.no/hires/ 1 Link to comment Share on other sites More sharing options...
Rodney Lyne Posted April 13, 2019 Author Share Posted April 13, 2019 3 hours ago, Irek said: First of all cheap bluray players don't have a DAC, so they can work only as a transport. Unless you think about something like $600 Ultra HD Blu-ray Player DP-UB820. So, the answer is $600 bluray player with whatever high resolution files cannot compete with $2000 CDP. $300 BRP + $1000 DAC still is worst than $2000 CDP. $1000 DAC with asynchronous usb connection to laptop will get close. CD quality is actually very good, I have a problem to distinguish the difference between CD and high res files. Have a look at http://www.2l.no/hires/ I find it quite fascinating all the different options and possibilities. Especially with the advancement of technology. Link to comment Share on other sites More sharing options...
Rodney Lyne Posted April 13, 2019 Author Share Posted April 13, 2019 4 hours ago, Irek said: CD quality is actually very good, I have a problem to distinguish the difference between CD and high res files. Have a look at http://www.2l.no/hires/ I did read an article the other day about streaming audio that after 320 kbs alot of people cant hear much difference with cd quality. I'm guessing the difference with cd and flac would be even smaller. I will check out the link thank you Link to comment Share on other sites More sharing options...
proftournesol Posted April 13, 2019 Share Posted April 13, 2019 I use my Panasonic 4K player as a transport into my Weiss DAC as well as my dedicated CEC CD transport, also connected to my Weiss via SPDIF. It's no contest really, the Panasonic is way behind in sound quality 3 Link to comment Share on other sites More sharing options...
Rodney Lyne Posted April 14, 2019 Author Share Posted April 14, 2019 So the general consensus would be even though the blueray player has ability to play sacd and flac I would be better off looking for a good cdplayer and upgrading my dac, to get the most out of my speakers 1 Link to comment Share on other sites More sharing options...
Hi-Fi Whipped Posted April 14, 2019 Share Posted April 14, 2019 24 minutes ago, Ashtray83 said: So the general consensus would be even though the blueray player has ability to play sacd and flac I would be better off looking for a good cdplayer and upgrading my dac, to get the most out of my speakers Yep Link to comment Share on other sites More sharing options...
Rodney Lyne Posted April 14, 2019 Author Share Posted April 14, 2019 I should probably start a new thread for this, but I have been looking at a few cd players local to me and a primare D20 is available for under $500 it looks reasonable. Has anyone used this before Link to comment Share on other sites More sharing options...
Rodney Lyne Posted April 14, 2019 Author Share Posted April 14, 2019 Another local option I could look at is a marantz cd 63 mkii ki signature. Again around $400, I had not set a budget yet but just looking at what is around that could be good Link to comment Share on other sites More sharing options...
Rodney Lyne Posted April 16, 2019 Author Share Posted April 16, 2019 Ok new thread started as no reply s to this one. Link to comment Share on other sites More sharing options...
rudihaas Posted May 21, 2019 Share Posted May 21, 2019 Keep your Blu ray and add a external DAC for your 2 channel , or have I missed something (didn't you say there was a Xtra HDMI)...... Link to comment Share on other sites More sharing options...
Rodney Lyne Posted May 22, 2019 Author Share Posted May 22, 2019 On 12/04/2019 at 2:18 PM, betty boop said: yes just HDMI and coax out... if you get the chance id encourage to try a dedicated cd player just analog out into your vincent Sp dif and two hdmi one is audio only 1 Link to comment Share on other sites More sharing options...
betty boop Posted May 22, 2019 Share Posted May 22, 2019 23 minutes ago, Ashtray83 said: Sp dif and two hdmi one is audio only Indeed I was suggesting dedicated CD player via analog out to the Vincent. other option as suggested above I’d get a dac, though no idea how good pana is as a transport and CD players are so cheap ! Link to comment Share on other sites More sharing options...
mixdown Posted May 23, 2019 Share Posted May 23, 2019 I use a Denon Pro CD/MP3 player as transport for CD's connected via coax to a Musical Fidelity DAC. Works a treat but still doesn't sound as good as vinyl..... 1 Link to comment Share on other sites More sharing options...
