Muscle Mat - thick shaggy rug for room treatment
Did a quick search and couldn't find a mention of these, and as I'd never heard of them before a couple of weeks ago I thought I'd post them here.
I saw one of these at my nephew's place and have subsequently ordered a couple for my lounge room.
Stupid name, but essentially these are a shaggy, 35mm thick foam rug that works well to tame a lively room.
A couple of tips if you decide to try one:
Do a Google search for Muscle Mat discount code. You can often find 10-15% off codes.
Once unwrapped leave it flat without anything on it for 4-5 days as they are shrinkwrapped at the factory and need to time to fully expand to the end thickness.
https://www.musclemat.com.au/products/deluxe-shaggy-relax-mat
I was all excited than as I thought it said Shag on mat😉
Looks like a more convenient version of what I use; a 100% wool, 2cm thick, cut pile rug over two layers of Bunnings foam underlay.
Works very well as claimed above, and is nice to sit on too.
Edited by Steever
  • Author
I'm sure they'd work fine for that too 🙂
  • 3 months later...
only beneficial to absorb the top end if that's an issue...
or she's on top
