I was wondering for the xbox360, should i set the output to 720p or 1080i? From wat i know 720p is digital, whereas 1080i is analog but has more TV lines so better? Which one is better? confused...
If you have a native 1080i/p or 768p display, then I would set it to 1080i. Otherwise, I would set it to 720p.
Yeap...agreed in unison with tsammyc. If your Display is HD-Ready as in able to accept both 720p and 1080i - set 1080i/p on your XBox 360 under the Display Option. It will yield better results.
What about a native 1080p display? Should I still use 1080i? Unfortunately my display does not accept 1080p over component :(
Yes, you can set the Display to 1080i.
Yes! use 1080i instead of 720p if possible. But if you're viewing from an LCD TV - chances are there may not be any 'significant' difference in terms of PQ. Trial and error.
Most of the Projector users will choose 1080i for XBox 360 Display option even though the native resolution for the Projector is 720p.
