MusicByTheFire Posted September 11, 2020 Share Posted September 11, 2020 Hi All, Just thought I would share a fix for volume control issues on Marantz receivers (volume not changing when volume knob turned). Turns out the problem was too much damping fluid injected during assembly of volume sensor resulting in electrical contact insulation in volume sensor wheel. Rather than unsolder the volume wheel and make life hard for myself, one just removed the metal containment clips of the volume sensor and cleaned the contact wheel with isopropyl alcohol. Pictures attached. Hopes this assists Hi-Fi enthusiasts with same issue. No liability assumed by poster for dead amplifiers or electrocution Link to comment Share on other sites More sharing options...
Jude Perreira Posted September 11, 2020 Share Posted September 11, 2020 Hi Andrew, thanks for sharing on how to fix the volume control on a Marantz amp. I have the same issue but I use the remote control, now that you have shared this info I will try to fix this. Kind Regards, VJJP. 1 Link to comment Share on other sites More sharing options...
