DubbyMcDubs Posted February 18, 2020 Share Posted February 18, 2020 Item: Cayin CS-88A Integrated Valve Amplifier Location: Central Coast NSW Price: $2,500 ono Item Condition: Mint, As New Reason for selling: Upgrading/Change of direction Payment Method: Pickup or Post - Cash, EFT, Paypal + 2.6%, COD Only Extra Info: I have owned this amp since July this year. Originally purchased in preparation for a setup with Klipsch Cornwall III speakers, however I went a different route and ultimately purchased Revel M106’s. While this is an exceptional sounding valve amplifier it is not really matched well with the Revel’s and I have since upgraded to a Benchmark system. The build quality is exceptional, regardless of price. Selling to help fund the upgrade. This amp is in mint as-new condition, with no more that 5 hours use on it total. I have all of the original packaging and accessories. 19 months warranty remaining. Retails for $3,499. Selling $2,500 ono Happy to post if buyer pays postage, but realize its a very heavy item. Specifications Power Output: 25 Watts per channel (Triode) 45 Watts per channel (Ultra-Linear) Frequency Response: 10Hz - 42kHz (-3dB) Total Harmonic Distortion (THD): 1% (1kHz) Signal to Noise (S/N) Ratio: 93dB Line-Level Inputs: Two Phono Input (MM) Pre-Amp Input: One stereo preamp input – allows the CS-88A to be used as a power amp only Construction: Hand-made construction with silver point-to-point wiring Power Supply: Specially designed toroid transformer for the power supply Pre-Amplifier: Two 6SL7 and two 6SN7 valves are used in the preamp stage Four KT88 valves are used in Class AB1 push-pull output stage Triode and Ultra-linear selection via remote Bias Adjustment: Easy valve bias adjustment using the top mounted bias meter Rear Panel Switch: Switch easily between the supplied KT88 output valves or optional EL34 valves via a convenient rear panel switch Remote Control Soft Start Function: 30 second soft start function - extends the life of internal components and valves Memory: CS-88A stores last usage settings once turned off Volume Control: High-quality Japanese ALPS motorised potentiometer (volume control) Silver Plating: Heavily silver-plated signal cables are used throughout Cover: An easily removed cover is provided for protection from hot valves Speaker Binding Posts: Accepts Banana plugs or spade terminals Output Impedance: 4 Ohms and 8 Ohms Power Cord: Standard IEC that can be easily upgraded. Dimension (WxHxD): 420 × 195 x 382 mm Net Weight: 28kg Photos: Link to comment Share on other sites More sharing options...
