March Audio speaker cables, Canare 4S11, 5 metre pair
Further Information:
March Audio speaker cables using Canare 4S11 cable with 4x 14AWG conductors; length 5m with locking banana connectors both ends
Bought these here in 2022, can be bi wired.
Don't need this length anymore.
Professional Canare 4S11 cable
Star Quad geometry
Low noise, resistance and capacitance
The NFS series are exceptional quality speaker cables at affordable prices.  The NFS series is manufactured using Canare 4S11 professional cable and fitted with your choice of gold plated locking bananas or spade connectors.  These cables will ensure the absolute integrity of the musical signal from source to destination. The 4 x 14 AWG conductors are arranged in a star quad geometry.  This rejects noise and ensures low capacitance and inductance.  An exceptionally transparent connection.
The high quality gold plated locking banana plugs provide a very low resistance connection that wont work loose or fall out.
Hi. Is each cable 5m or are the pair of cables 5m in total (i.e 2.5 metres each)?
A five metre pair means exactly that  i.e a pair of cables where both cables are five metres in length. A 2.5 metre pair would be where the two cables were both 2.5 metres.
I hope this helps
