Bush thug Posted May 17, 2022 Posted May 17, 2022 (edited) trying to get my power amp to go on/off when the zone 2 on my marantz receiver is switched on or off. is ther anything I can buy to do this or its just not possible. the reason I need this is because I am setting up a system outside but the ups will be upstairs and speakers down stairs and controlling it by an app. so be handy if I could just switch on or off from there. or if I have to an amp with the feature built in that will work with focals. Budget $1000 Edited May 17, 2022 by Bush thug
Guest Posted May 17, 2022 Posted May 17, 2022 For the amp, you can get something like this https://www.audiophonics.fr/en/diy-kits-and-boards/audiophonics-trigger-12v-230v-slave-power-supply-device-p-10661.html But the difficulty is triggering this device when it senses a Zone 2 signal. Maybe your can use this??? https://www.amazon.com.au/DS18-V5HL-High-Level-Technology-Aftermarket/dp/B07C723VT4 Given your budget, I wonder whether it is easier to get Heos powered speakers and do away with the complexity of this setup.
Bush thug Posted May 18, 2022 Author Posted May 18, 2022 awesome thats what I need. just ordered it. I am all about complex setups. I like being the only one that can use my righa haha.
