Retro fit double glazing for noise reduction
1 hour ago, Peterbean said:
If noise is like heat then the best thing you can do is to plug up the gaps, go round and feel for air leaks around doors windows, everything .
ive used magnetic window layers in 2 houses, they are effective, and as said above they don’t necessarily combine well with all types of windows. They are best over fixed panes.
acrylic is a better’ insulator than glass
lwith Magnetite I’ve always removed them in summer but you would loose the sound insulation- but then you would if you open windows in summer, which one tends to do
Hi Steve
Any ideas for standard wooden room door sound  leaking
I have a solid core door for my sound room, but noise still gets through the gaps
Thx mate
  • Replies 26
  • Views 7.4k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • We've had our new double glazing retrofit in for over a week now. Obvious thermal benefits, and I noticed our ducted gas heating unit turning off and on far less. The house is holding temperature much
  • I had a bespoke door and frame made for my mancave and I went to the big glass manufacturer up here G.James Glass to get double glazed panels to put in it and the manager overheard my order and he sai
  • @Marc, in the end I didn’t go with the double glazing retrofit. It would have looked like retro fit and it wasn’t the look I was after. A few months ago I had to replace some broken glass in one
18 minutes ago, blownaway said:
Hi Steve
Thx mate
https://greenityourself.com.au/
