francis wu Posted November 6, 2018 Author Posted November 6, 2018 If you are in China...crab this excellent deal....S$675 only! ;D https://www.gizmochina.com/2018/11/05/oneplus-6t-with-purple-color-variant-3399-yuan-493-starting-price-unveiled-china/
francis wu Posted November 6, 2018 Author Posted November 6, 2018 Another top phone to consider when you are in China...…choices, choices... https://www.gizmochina.com/2018/10/31/honor-magic-2-is-official-slider-design-amoled-display-triple-cameras-in-display-fingerprint-scanner-and-lots-more/
Knight_Rider Posted November 6, 2018 Posted November 6, 2018 On 06/11/2018 at 8:12 AM, Gondon72 said: havent really use, waiting for my screen protector to reach singapore. should be tomorrow or wed. good to know battery can last long :D You can use the smart cover. Alternatively you can get the UV screen protector from huawei shop (stock always run out). That one use glue like Note 9 because dome shape.
Gondon72 Posted November 7, 2018 Posted November 7, 2018 On 06/11/2018 at 9:50 AM, Knight_Rider said: You can use the smart cover. Alternatively you can get the UV screen protector from huawei shop (stock always run out). That one use glue like Note 9 because dome shape. I received my taobao order liao...going to try the screen protector tonight :D
Knight_Rider Posted November 7, 2018 Posted November 7, 2018 Hand must be steady. In case of emergency use this. Hearsay the toa payoh outlet not bad. https://www.facebook.com/whitestonesg/
Knight_Rider Posted November 7, 2018 Posted November 7, 2018 On 07/11/2018 at 3:45 AM, Gondon72 said: I received my taobao order liao...going to try the screen protector tonight :D Make sure the screen protector is tokong. Take screenshot is knocking on the screen twice. Lucky can use assistant too. ;D
Gondon72 Posted November 7, 2018 Posted November 7, 2018 On 07/11/2018 at 10:29 AM, Knight_Rider said: Make sure the screen protector is tokong. Take screenshot is knocking on the screen twice. Lucky can use assistant too. ;D alot having the problem with the thumbprint after putting screen protector...hope this works
francis wu Posted November 7, 2018 Author Posted November 7, 2018 Aiyah, no need screen protector lah![emoji6] Sexy8
francis wu Posted November 7, 2018 Author Posted November 7, 2018 Another new design to hide the front cameras :)
Knight_Rider Posted November 7, 2018 Posted November 7, 2018 On 07/11/2018 at 11:30 AM, Gondon72 said: alot having the problem with the thumbprint after putting screen protector...hope this works The Huawei UV one confirmed works. But brightness level always shift. Go to developer option to deactivate Sunlight readability.
Gondon72 Posted November 7, 2018 Posted November 7, 2018 On 07/11/2018 at 1:19 PM, Knight_Rider said: The Huawei UV one confirmed works. But brightness level always shift. Go to developer option to deactivate Sunlight readability. sianz..the screen protector ok..but once put casing it pushes up the protector..lolx...got to wait for whitestone liao
Knight_Rider Posted November 7, 2018 Posted November 7, 2018 On 07/11/2018 at 1:52 PM, Gondon72 said: sianz..the screen protector ok..but once put casing it pushes up the protector..lolx...got to wait for whitestone liao Casing problem not screen protector. I LL use HW smart cover. The other clip case very little protection. So far only this 2 can use.
Gondon72 Posted November 7, 2018 Posted November 7, 2018 On 07/11/2018 at 1:56 PM, Knight_Rider said: Casing problem not screen protector. I LL use HW smart cover. The other clip case very little protection. So far only this 2 can use. me using spigen casing...saw in HWZ got one shop in waterway point have a TG protector that suits it...$49.90...
Knight_Rider Posted November 7, 2018 Posted November 7, 2018 On 07/11/2018 at 2:26 PM, Gondon72 said: me using spigen casing...saw in HWZ got one shop in waterway point have a TG protector that suits it...$49.90... TG I think I saw at challenger. There are some Made in Japan ones.
Knight_Rider Posted November 7, 2018 Posted November 7, 2018 This irritating problem since mate 10 days. https://forum.xda-developers.com/mate-10/help/huawei-mate-10-pro-display-dimming-t3740528
Gondon72 Posted November 8, 2018 Posted November 8, 2018 Aiyah, for me worst lah...having the first class problem, my game not in full screen mode. Status bar overlap the upper game screen and navigation bar overlap my action button. my mate 9 doesnt have this problem, yet the new mate 20 pro got this issue...beri sianz..
Knight_Rider Posted November 8, 2018 Posted November 8, 2018 On 08/11/2018 at 3:00 AM, francis wu said: turn to auto brightness ::) Need the system to register the developer option first. I off developer option off auto brightness cannot. Some apps still trigger auto brightness. Same like themes need the system to acknowledge first or else cannot find the my button in themes.
Gondon72 Posted November 8, 2018 Posted November 8, 2018 On 08/11/2018 at 6:12 AM, Knight_Rider said: Full screen mode is game dependent. Yes. But mine is at full screen when playing with mate 9. but it doesnt on mate 20 pro...
Knight_Rider Posted November 8, 2018 Posted November 8, 2018 Some apps need to close and open again while some need to backspace and reopen. Android Pie may have some bugs too.
domho8 Posted November 8, 2018 Posted November 8, 2018 On 08/11/2018 at 10:32 AM, Knight_Rider said: Some apps need to close and open again while some need to backspace and reopen. Android Pie may have some bugs too. lu bo feedback to huawei ah
Knight_Rider Posted November 8, 2018 Posted November 8, 2018 On 08/11/2018 at 10:39 AM, domho8 said: lu bo feedback to huawei ah I still waiting for them to exchange my phone. The green tint very obvious
domho8 Posted November 8, 2018 Posted November 8, 2018 On 08/11/2018 at 10:50 AM, Knight_Rider said: I still waiting for them to exchange my phone. The green tint very obvious Wa u Kena the green lantern ah. Knn must change ah. Sent from my Redmi 5 Plus using Tapatalk
FookLai Posted November 9, 2018 Posted November 9, 2018 On 08/11/2018 at 10:50 AM, Knight_Rider said: I still waiting for them to exchange my phone. The green tint very obvious I read in China that Huawei is very serious in this issue and they promised to let user change till they satisfied with the new set. Meaning you can keep changing and changing for new set if got the green tint issue. How about Singapore?
