Stereolove Posted June 2, 2023 Share Posted June 2, 2023 Item Condition: New Shipping Options: Shipping is included in price. Suburb or Town: Essendon State: VIC Payment Method: PayPal Reason for selling: Not required Further Information: Vertical pin structure achieves uniform pressure of electrical contacts. Contact surface stabilized by spherical washer Conventional head shells have the connecting pin attached only to the upper side, causing uneven contact pressure between the arm and the head shell. However, this model adopts both an upper and lower pin structure, equalising the pressure on the contacts and applying force evenly across the connection to the tonearm. Moreover, by using the spherical head shell washer developed independently at the contact point with the tonearm, stable contact is achieved over the entire circumference of the contact point, providing improved stability and resonance control. Machined Ultra Duraluminum DS Audio precision machines each HS-001 out of a solid billet of duralumin for the ultimate in rigidity and resonance control. Hand soldered Litz signal leads After extensive listening tests within the company, DS Audio chose a Japanese made Litz wire. Further advances were realized by hand soldering this delicate lead wire to preserve signal integrity for the optimal in sound performance. Link to comment Share on other sites More sharing options...
