SONIC ART SILVER REFERENCE RCA 1 mtrPAIR
Further Information:
SILVER REFERENCE
Interconnect cables Featuring triple 'Time Aligned' conductors.
• SILVER Reference RCA is a culmination of our cable technology and has been designed to exhibit a broad frequency response whilst maintaining a full bodied liquid soundstage. A very low noise floor creates a very black background and an incredible holographic image.
• SILVER Reference RCA features our optimum conductor sizing in our Military Grade 4N Silver & 6N Copper alloy, individual hot and cold runs maintain signal separation. Triple 'Time Aligned' core construction is covered by our Silver plated copper shield and then insulated in VIRGIN PTFE (Pressure cast Teflon) and Antistatic Polyester sheathing. Now terminated with CARDAS Eutectic alloy, Silver/Rhodium plated plugs; these are the best plugs CARDAS makes and finish off this incredible cable.
• SILVER Reference RCA is assembled by hand, and like all our cables each pair comes from the same cable batch and run. The antistatic sheath is laid over and heat shrunk in place, the wire is then soldered directly to the Silver plated plugs with CARDAS Quad Eutectic Silver solder. The plugs are sealed and then labelled for direction. Each pair is tested and run before packing ready for shipment.
All Sonic Art cables are hand assembled in Melbourne AUSTRALIA to exacting standards.
Our cables produce a smooth transparent soundstage with excellent detail, placement and depth, a lack of harshness and grain immediately noticeable
SILVER Reference Interconnect Specifications:
Wire: MILSPEC 4N Silver/Copper. Perfectly round conductors. Time Aligned triple core design. Separate Hot and Cold runs. Floating shield
Insulation: MILSPEC pressure cast Teflon with MILSPEC Silver Braided shield. MILSPEC pressure cast Teflon outer jacket with Polyester Antistatic outer mesh sheath
Termination: CARDAS Eutectic Alloy Silver/Rhodium plated RCA plugs, all connections made with CARDAS Quad eutectic silver solder
Note: Sonic Art SILVER Reference must be run in the direction of the lettering
Sonic Art Cables require 150+ hours of use before reaching full performance
Edited by ray4410
