quite easy to change, most r those round
nickel batteries u can try open up n c
anyone knows how long the battery can last?
and where can i get it change around AMK area?
Tks  :)
most photo shops stock it.  may even find it in econ minimart...found some rare battery which I couldn;t even get from neighbourhood hardware shops!
the battery inside is the button type, but what i was told tat if just open up and change the battery, the set frequency will run and may affect the operation of the car alarm system. just want to clarify.  Tks  :)
oic!  So far I've not have any using button type (Li?) batt.  Yours is integrated with the key?  I don't think the code will run lah...these days cannot be so c0ck-up one lah!
Wah, whoever told you that either want to make you pay $$$$$$$ for a simple battery change, or doesn't have an idea what he is talking about.
No problem one la.
