Hi all,
I have just a few quick questions about the PS3 that so far I haven't been able to find the answers to....:
(1) are PS2 controllers supported on the 40Gb PS3? ... How about multi-taps?
(2) Is it possible to specify output of blu-ray movies to 720p and 1080i? Do these settings preserve 24hz framerates?
Thanks!!
andrew
Hi all,
Thanks!!
andrew
1) You can get an adapter - I've seen them in the shops.
2) Yes you can set resolution. No 24Hz is a 1080p only feature AFAIK.
