PS Audio Dectet Power Center
I’ve changed my setup, so this is no longer required.
I can provide a stock black IEC cable, or ask about other cables I have of different lengths and brands if interested.
Can post at buyer’s expense, where I will pack it securely.
Further Information
From PS Audio
DECTET AC POWER CONDITIONER
Power your entire system with the Dectet to clean, protect, and improve.
The Dectet is an active three zone, ten outlet power center that produces clean, unrestricted AC power for an entire high-end audio or video system. It is designed to power and fully protect your entire system with improved dynamics, increased harmonic integrity, and an open, spacious soundstage that can be breathtaking. Filtration is handled through large core high permeability magnetic devices wound with heavy gauge OFC providing both common mode and differential mode filtering you can both measure and hear. Protection is through both microprocessor controlled over/under voltage surge guard and MOV spike that will always make sure your equipment is fully protected.
The Dectet Power Center is built to power and fully protect your entire system with improved dynamics, increased harmonic integrity and an open spacious soundstage that can be breathtaking.
Ten individually hand wired Power Port outlets, three isolated zones and all available at a price you can afford. Filtration is handled through large core high permeability magnetic devices wound with heavy gauge OFC providing both common mode and differential mode filtering you can both measure and hear. Protection is through both microprocessor controlled over/under voltage surge guard and MOV spike that will always make sure your equipment is fully protected.
Each of the Power Port outlets on the Dectet are hand wired with a star wiring system that provides similar benefits to having individual dedicated lines feeding each piece in your high-end audio system.
Best of all, the Dectet is hand built in our Boulder Colorado facilities by skilled craftsmen who care about the products they build with the PS Audio brand on them.
Features:
  • 3 isolated zones
  • 10 receptacles
  • Individually hand wired outlets
  • Common and differential mode filtering
  • Over/under voltage protection
  • Surge protection
  • Spike protection
  • Handles an entire system
20240401_220410.thumb.JPG.ac6422f8d7370fd200255ff35ac718bc.JPG20240401_220459.thumb.JPG.41ab9d19d75f11202ed457787a0ba3a2.JPG
