Audio related semiconductors
Further Information:
List below.
Type    Quantity    Description    Condition
Adapter - IC    2    SMD to PCB pins - Aprilog 32QFS20-D6-SMT-S    New
Crystal oscillator    5    12.000 mhz cmos Crystek    New
Heatsink    2    TO-220 Verticle    New
Heatsink    4    TO-220 Verticle    New
Heatsink    2    TO-220    New
IC DIP Header    2    14 pin    New
Semiconductor - amplifier    1    LM4780TA    New
Semiconductor - amplifier    4    LM1875T IC AMP CLASS AB MONO 25W TO220-5    New
Semiconductor - buffer    6    AD815AYS Dual High Output-Current Differential Driver 15SIP    New
Semiconductor - DAC    6    TDA1543 Philips i2s NOS    New
Semiconductor - DAC    1    PCM2707 USB SMD 32-TQFP    New
Semiconductor - diode    4    MBR1100 schottky 100v 1a DO-41    New
Semiconductor - diode    6    CR360 3.6ma current regulator    New
Semiconductor - diode    4    STPS3045CP Diode Array 1 Pair Common Cathode 45 V 15A TO-218AC    New
Semiconductor - diode    24    1N5247B-T Zener Diode 17 V 500 mW ±5% DO-35    New
Semiconductor - diode    4    1N4004-T Diode 400 V 1A DO-41    New
Semiconductor - diode    2    MBR20100CT DIODE SCHOTTKY 100V 10A TO220AB    New
Semiconductor - diode    40    BYV26C Diode 600 V 1A Through Hole SOD-57    New
Semiconductor - Diode    22    SB1100 DIODE SCHOTTKY 100V 1A DO41    New
Semiconductor - Diode    16    SF12 1.0A 100V fast    New
Semiconductor - Diode    100    RG1B 100V 1A 2-Pin DO-204AP    New
Semiconductor - diode bridge    4    600v 35a db3506p    New
Semiconductor - LED    4    LED 5mm dual colour reg/green    New
Semiconductor - LED    >15    Assorted    New
Semiconductor - MOSFET    12    IRFI720G    New
Semiconductor - opamp    4    OPA2134PA Dual Audio Opamp    New
Semiconductor - receiver    5    CS8412-CS Digital Input Receiver    New
Semiconductor - receiver    4    CS8414-CS Digital Input Receiver    New
Semiconductor - regulator    1    LM337T Regulator Neg Adj TO-220    New
Semiconductor - regulator    1    LM317T Regulator Pos Adj TO-220    New
Semiconductor - regulator    2    MC7808CT    New
Semiconductor - regulator    20    IXCP10M45S current regulator    New
Semiconductor - regulator    1    NJM78M08FA 8v positive regulator TO220F    New
Semiconductor - regulator    1    NJM79M08FA 8v negative regulator TO220F    New
Semiconductor - regulator    10    LT1086CT 25v max input 1.5a adj positive regulator    New
Semiconductor - regulator    2    REG102UA-5v regulator    New
Semiconductor - regulator    2    MC7908CT    New
Semiconductor - transistor    3    BC550C Bipolar (BJT) Transistor NPN 45 V 100 mA 250MHz 625 mW TO-92    New
Semiconductor - transistor    2    MMBFJ309 RF MOSFET N-CH JFET 10V SOT23-3    New
Semiconductor - transistor    10    BC546BG NPN GP 100ma 65V TO92    New
Semiconductor - transistor    6    2N4403RLRAG PNP GP 600ma 40v TO92    New
Semiconductor - transistor    2    MJE3055TG NPN 10a 60v TO-220AB    New
Semiconductor - transistor    2    BC556B NPN    New
Semiconductor - transistor    10    2N3906 PNP    New
Socket - IC    3    14 pin - solder    New
Switch - DIP    4    8 pin    New
Terminals - PCB push    Assorted        New
Terminals - PCB screw    Assorted        New
