PeachTree Audio Nova125 Amplifier with DAC
Further Information: Today we invite you to enter a realm of audio bliss with the Peachtree Audio Nova125 Amplifier with DAC, now available in good secondhand condition at Len Wallis Audio!
**Important update**  - although the unit is good secondhand condition - this until does have a blemish on the front leading edge - please see the attached photo.
Feel the rush of 125 watts per channel effortlessly driving your speakers, delivering crystal-clear sound with every note. No matter the volume, no matter the genre, the Nova125 delivers performance that satisfies. For its time when first launched in 2014 it was a device of innovation with its built-in 24/192 up sampling DAC, Hybrid Tube Preamp, and dedicated Headphone Amp, the Nova125 is effectively not one but four products packed into one chassis.
With power output up to 125Wpc @ 8 Ohms and 220Wpc @ 4 Ohms, along with a plethora of inputs and outputs including USB, coaxial S/PDIF, and optical S/PDIF, this amplifier is ready to handle whatever you throw its way. Plus, with a sleek and compact design, it fits seamlessly into any audio setup without taking up precious space.
Whether you're streaming lossless downloads or spinning your favorite vinyl, the Nova125 ensures that your music sounds exactly as the artist intended. Don't miss out on this opportunity to own a piece of audio history. Contact us today!
Specifications
Power Output: 125Wpc @ 8 Ohms, 220Wpc @ 4 Ohms
Inputs:One asynchronous USB, two coaxial S/PDIF, one optical S/PDIF, one stereo analog, one 12V control signal.
Outputs: Speaker taps, 1/4-inch headphone jack, one variable level stereo preamp output.
DAC: ESS Sabre 9023 Jitter: <3ps measured at master clock.
Resolution levels supported: MP3, 16/44.1, 16/48, 24/88, 24/96, 24/176, 24/192
USB: Asynchronous up to 24/192
Optical: Up to 24/96
Coax: Up to 24/192
Valve complement: One 6N1P (used for headphone amp, switch selectable valve buffer stage)
Frequency response: 20Hz-20kHz +0.5dB S/N: 96dB
Dimensions (HxWxD): 111 x 376 x 292mm Weight: 9.82kg
Edited by LWA Staff
Updating - to advise on minor damage on this unit.
