HT / Audio Room lighting
Hi, there is plenty of threads with discussion on room treatment, speakers, electronics etc. I am wondering what most of you are using for lighting in your HT/Audio room. I believe design and lighting will affect the mood when enjoying your music/movies. Toying with the idea of installing some ambient or mood lights when listening to music (movies strictly off all lights) without much  major electrical revamp works. Hope to get some ideas from you guys.
Sent from my ONEPLUS A5000 using Tapatalk
  • Replies 37
  • Views 9.3k
  • Created
  • Last Reply
Top Posters In This Topic
Ambient light strip behind console
Philips Smalu variable lights (change temp and intensity)
Central pH5 pendant lamp for general illumination
Track lights with LED for display cabinets
Corner uplifter lamp for ambience
(plus some table lamps)
And a Atmos signboard....
I used Philips hue lightnings for all my setup
  • Author
Nice! Keep the photos coming in. I ordered some cheap EL cold lights from China to try. Yet to arrive. Can't go big scale as I dun wanna touch electrical points.
Sent from my Mi A1 using Tapatalk
Mainly i used for display bah than hifi....
Philips Hue is a good option...got Alexa and HomeKit support... led strips and lamps too (E27) so use in existing fittings.
only hassle is expensive and must use mobile/tablet to control or voice (Siri etc) or extra dimmer switch from Hue range. Can see at Philips showroom or apple shop too I think
  • Author
I used to have their smart bulb (e27). Not bright enough for practical use I feel.
  • 1 month later...
I visited Atx's mancave a few weeks back and was mightily impressed with the ambience and lighting in his room. Tried to copy a bit and this is the best I can do now ;D U can view his setup on the eqpt list thread under ABC. I can't view it on my hp tho
  • 3 weeks later...
Very nicely done bro. Swee!
here's my recent setup tv was a bit off centre as past setup is smaller scale....as tv was used for casual youtube and etc and music listening so didn't bother to remount it
For movie/concert viewing mainly used projector so centre channel was centre
  • Author
Does the LED light behind the TV change color base on what's being displayed on screen?
no u need to buy philips hdmi sync box which is $229USD i think for you to do that...cheaper way is using apps control
  • Author
Sent from my LYA-L29 using Tapatalk
So nice! Are the rabbit lights sharing same power points with ur equipment?
... b9e444f8f2f489a40fa4b889247c468d.jpge16b5a134fa021bf854f0d56c50712c5.jpg7a834a8ce95b223a10556acc754a084e.jpg
Thanks chaozhoi....rabbit lights is in separate power point.
Soular Energy and Flamenco Fever spotted at pride of place positions!
Wah... you have eagle eyes ...that’s a reissue only...
Saw a lot of bearbricks on display.....
hee hee
  • 3 weeks later...
;D
  • 3 weeks later...
This one consider as lighting or not? haha....
37296170_10156438026372296_919157404032040960_n.jpg?_nc_cat=106&_nc_sid=05277f&_nc_ohc=RWcnfxpdcUcAX_WFiED&_nc_ht=scontent.fsin3-1.fna&oh=59ee7cbb310687dacdb93b3a35b31810&oe=5E921EC2
Where is your ATC?
(Audio)
Where is your ATC?
(Audio)
This one old photo 1 years plus ago
  • Author
Ok. Today just installed mine after many months. 8c03e669e086b921817439e3d88507e2.jpg
  • 1 month later...
My lighting
95505323_10158109380717296_8159966687307759616_n.jpg?_nc_cat=108&_nc_sid=110474&_nc_ohc=siCH3E2lnsoAX_UU3Rh&_nc_ht=scontent.fsin3-1.fna&oh=3175988a93ca6f3c487ab5feb83de805&oe=5ED1D02A
95877184_10158109380747296_4854213604632690688_n.jpg?_nc_cat=104&_nc_sid=110474&_nc_ohc=odU1r35AWncAX-z9BmU&_nc_ht=scontent.fsin3-1.fna&oh=52d3901b205c82dc3a1b9440857d84a0&oe=5ED11A86
94886538_10158109716607296_1606440093667557376_n.jpg?_nc_cat=104&_nc_sid=110474&_nc_ohc=iXSSaYeQmYYAX8C8ILH&_nc_ht=scontent.fsin3-1.fna&oh=1a2f78206eec0d0c83fd30c5d428e7ae&oe=5ED262B0
95374366_10158109380682296_3921128570847494144_n.jpg?_nc_cat=110&_nc_sid=110474&_nc_ohc=s-baqNwZwbEAX8fVO4U&_nc_ht=scontent.fsin3-1.fna&oh=4a39f3f78cbc164e453e7212e6660a10&oe=5ECFD9AB
