Atlas Gouverneur Posted January 2, 2013 Author Posted January 2, 2013 Well after a couple months of slow progress i am nearly at the 'end' of my room renovation. After discovering how expensive acoustic building products are i decided to leave most of it behind and use the primary law of adding mass. Almost 2 tones of mass was added to the room, in the form of 16mm plasterboard, MDF, particleboard and compressed strand bamboo flooring. My father had accidentally bought 35 tubes of grey polyurethane instead of black, understanding that polyurethane would most probably be inferior to green glue i decided to use it in favor of saving a substantial amount of money. What i am left to do now is the door and the reveal, skirting's and electrics.
Jventer Posted January 2, 2013 Posted January 2, 2013 Looking good, you have worked hard. All the best with the rest.
Atlas Gouverneur Posted January 5, 2013 Author Posted January 5, 2013 thanks jventer.Hopefully the rest is done soon!
