My mini home cinema
  • Author
Sure bro
  • Replies 235
  • Views 95.5k
  • Created
  • Last Reply
Top Posters In This Topic
Why are you selling everything!?
  • Author
Going to stereo . A difficult decision .
Sorry to hear it bro.
I like the way you do things though- give 100%. Am sure your stereo will be awesome!
Sad to hear that you have to give up your dream HT set-up after putting in so much effort.
  • Author
Thanks all . Now going into the stereo world. Lot of things to learn from the bros out there .
  • Author
Yup agree , except  for the low bass oomph .
There goes my reference system. Such a pity you have to go this path.
I think it helps to have a set up that can do both movies and stereo. I know you went the whole hog with an acoustically transparent screen but IMHO, I've often found it's a compromise on both fronts.
My wife let me have the dedicated room when we got our new place, so I was able to put the speakers way into the room for stereo and still be able to project a 120" 16:9 image from the projector.
Good luck with the 2 channel setup :)
Hi bro,
Just spoken to you about a week ago only.  Really shocked :o and sad :( to know that you have decided to give up your HT.
What a pity.  I have yet to visit and take a look at one of the reference HT setup.
Anyway, I wish you all the best in your path to Stereo.  Given your dedication and commitment, I believe your future Stereo set up will be as awesome!
Cheers! ;D
  • Author
Not reference lah , just a simple setup .  ;D
Hi bro,
Cheers! ;D
+1...
You are the FASTEST guy that give it all up after a year!
I bet econav will be surprised by your move too...especially after he spent so much time with you :P
http://www.xtremeplace.com/yabbse/index.php?topic=106694.msg861554#msg861554
  • Author
Thanks bro .
Even Hifi can cause neighbor noise pollution. Maybe can consider some soundproofing? It's not that expensive (relatively).
TBH I think there is more mileage in hifi.
Depends. Hifi IMHO is usually a solitary pursuit whereas HT can be fun for the whole family.
How come ht and 2 channel audio cannot go hand in hand? Just take out the front 2 channel from behind the screen? Everything is about tuning and matching.
ht and 2ch together everything is more about compromise.
I don't find that to be the case.
Unless you integrate the 2 systems with things like ht bypass preamps and separate components etc.
True.
I meant there is more to tweak and refine in Hifi. But maybe it's because I am more easily satisfied with HT than Hifi.
sdds, funny. Thought you gave up stereo for home theatre a few years back?
True.
Got video to distract the ears. :)
Very very sayang....after all the effort , time , money spent...
Exactly. I'm easily distracted :D
Actually lack of funds is the best way to stop tinkering. :) I've been spending time to listen to stuff I've bought but not listened or watched. And ripping them to the server.
