The Ground Anchor from respected analogue audio specialist Origin Live is a grounding box that connects your tonearm ground(s) to your phonostage.
The family-owned company, entering its 40th year, says Ground Anchor reduces airborne noise, mains noise, system noise, and microphonic component noise. All of which affect the delicate signal produced during vinyl playback. It also marks the first collaboration with fellow UK manufacturer Puritan Audio Laboratories.
Origin Live CCO David Baker told StereoNET:
The beauty of vinyl playback is that it creates brand new electricity every time your cartridge stylus touches the groove. In contrast, the rest of the audio chain takes electricity from the mains, which is inherently noisy. Resolving this noise is a primary focus for every audio electronics engineer in every component in the audio chain.
The cartridge transducer converts mechanical energy into an electrical signal by induction between magnets and coils, meaning the power comes not from the wall, but from the little generator at the end of your tonearm. The problems of interference in vinyl playback are, on the whole, mechanical; hence, the endless search for solutions to vibration, resonance, and the transmission of mechanical energy.
Origin Live says that, despite the vinyl signal coming from a cleaner source and generally having a floating earth, it is still susceptible to picking up noise since the tonearm's tube and cable shielding acts as an antenna for RF and EMI. This audibly affects the signal within. The company adds that standard grounding reduces this considerably, but it is far from a perfect solution, leaving significant noise behind. This is where the Ground Anchor comes in.
For an electrical waveform, such as the cartridge signal, to exist, it must reference ground, or a 0V reference. The ground, which is connected to your mains, and the casework of your hi-fi separates are affected by airborne noise from radio frequencies, electromagnetic interference, as well as AC noise in the mains, which enters your system circuits. There is also microphonic and electrical noise generated within the system electronics.
Baker states:
Among audio signals, the vinyl signal is potentially the most vulnerable to airborne interference. The signal from an average MM cartridge is 5 mV, but for MC users, it can drop to as low as 0.1 mV. To move that signal effectively through a tonearm tube, without disturbing the mechanics of the arm, you are generally using thin unshielded wires, and asking the armtube to cover shielding duties. Where the armtube stands in as shielding, it needs to be grounded in order to transmit RF noise out of the system to ground.
The 160 x 65 x 40mm Ground Anchor, made to Origin Live’s specifications by fellow British firm Puritan Audio Labs, connects your tonearm's cable grounds to your phonostage's grounding post. The magic happens in a small black box containing a noise soak, which turns ground noise into harmless heat.
The result, Baker says, is “more signal clarity in all aspects, from detail and texture to blacker backgrounds, a little more separation between musical elements and more clearly defined aural forms”. He adds, “I was especially interested in how it performed with my Step Up Transformer: what you tend to gain in space and richness with an SUT, you often sacrifice in detail and attack. Connecting the Ground Anchor alongside my SUT lowered the noise floor, but also helped to retain resolution previously lost without.”
Unique to the Ground Anchor are the three grounding posts on the cartridge signal side of the product. This is for Origin Lives premium tonearm cables, which use multiple grounding wires: one for the tonearm structure, two for the cable shielding, and one optional ground for the signal (generally not needed).
According to Origin Live, this trio of options is to reduce hum by accommodating the different ways phono-stage designs reference ground (0V). Hence, three grounding posts instead of the usual one.
Universally compatible with all tonearms and phono stages, if your turntable doesn’t use multiple grounds, Ground Anchor can serve as a grounding box for up to three tonearms. It comes bundled with a 50cm copper ground cable, one side banana, one side adaptable banana (gold plated), spade, and Spring Clip Terminations.
The Ground Anchor is available from 20th February 2026 with an RRP of £545.
When exporting to countries outside the UK (where Origin Live does not have distribution and sells directly), it removes UK VAT from the RRP on all products. This 20% reduction more than offsets the tariffs, duties, and customs charges international customers face.
For more information visit Origin Live
00001354
Posted in: Hi-Fi
