MoFi Electronics is now offering its Ultra Low Noise Feet to UK music lovers. The MoFi ULNF promises substantial vibration control and noise reduction for any audio component.
The Ultra Low Noise Feet are said to have been developed in coordination with the acoustic experts at Harmonic Resolution Systems. The 4cm tall vibration mitigating pods featuring an outer housing of milled aluminium and dramatically lower the noise floor across the entire audio band while doing no harm in the frequency and phase domain, says MoFi.
The result, we're told, is that you hear more detail, nuance, texture, tone, focus, and clarity from their music.
Fitting the ULNF is simply a case of placing the component on top of the feet and use the provided level to check that everything is balanced.
MoFi says that the Ultra Low Noise Feet will enhance the sound from turntables, DACs, preamplifiers, CD players, power supplies, bookshelf speakers, and many other audio system components. They are available in three levels for progressively heavier separates and retail as a pack of four at the same price.
A set of four ULNF8-16 feet supports between 3.6-7.2 kg, the ULNF16-24 feet support between 7.2–10.9 kg and the ULNF24-32 feet support between 10.9-14.5 kg. RRP for a pack of four is £199 inc VAT.
See MoFi for more information
00002900
Posted in: Hi-Fi
