Single high-excursion driver 250mm( 10in), dual 229-mm (9 in) balanced-plane, high-velocity passive radiators, built-in advanced Class-D™ amplifier, USB Port / PBK Interface.
Power output is 1950 watts Dynamic Peak/650 watts RMS. Heavy, 29lbs.(13.5kg) ~ 300x300x300~
Wonderful sounding sub. Pulls it weight along with much larger subs.  Its sealed design and passive radiators putting it in a class of it own.
We have enjoyed this subs powerful and smooth sound.
It has the power and frequency response that allows you to feel sound effects as well as the ability to make a bass instrument sound low and smooth as it should.
Being relatively small in stature (but not in nature) allows it to be put away at the rear of a room or to be not intrusive in the front sound stage area.
There is no damage I can see, and the driver is in excellent condition.
Details:  https://tinyurl.com/8r3ttwtb
Review:  https://tinyurl.com/yszktmpu
(Also advertised elsewhere.)
Edited by bazzle
This is a ripper of a little sub. I replaced one with an SB2000 Pro to get more extension down in the low 20hz range. Despite not being able to go quite as deep I am convinced the quality of the bass produced from the ultra cube 10 was a step above and definitely better with music!
Im not sure. I purchased it 3 years ago from another member.
It hasn't played up at all.
Im only selling as I now have a Krix sub same age as my front Krix.
  • Thanks 1
This advertisement has been reported as Sold Elsewhere.
