Spider27 Posted October 14, 2021 Posted October 14, 2021 (edited) Further information: Very solid and heavy Hi-Fi audio rack. I believe that this is Australian Made and each layer height is adjustable to suit one's need. If you have large & heavy turntable, this would be ideal. I put massive idler TT on top and it was rock solid. + Dimension: 64cm (W) x 48cm (D) x 65cm (H) + Weight: Very heavy. + Condition: Overall good. Have some wear here and there but overall good. Each tempered glass is 11mm thick and full width and depth. Definitely two men's job to lift with tempered glasses on. If glasses are taken off, it should be fine for a person to lift so might be easier to move by taking glasses off. I had this for long time in my room but no longer required hence moving. Thank you. Photos: Edited October 14, 2021 by Spider27 1
