- I am one of the Beta Testers
- "Fully BDA compliant" means ? Is there a tool to verify ?
- Conexant's cx2388x driver supports multiple cards in the same PC since build 4.0.107.0 (The latest driver i got is 4.0.112.0).
I had tested 2 Stratford2(DVB-T) cards + 1 Oxford(Hybrid) card (=3 cards) in the same PC.
  • Replies 2.4k
  • Created
  • Last Reply
Top Posters In This Topic
The drivers that I am using are 4.0.107.3204 which I got from the CD ROM dated 110805. I'm not sure how to check what version of WinDTV I'm using.
I am able to install the drivers and the WinDTV application seperately, however if I then run Win DTV I get a message about can't find decoders. The card runs in MCE because it then uses the nvidia purevideo encoder.
WinFast DTV has it own's MPEG decoder (OEM from CyberLink).
WinFast DTV does not support the NVIDIA MPEG Decoder.
WinFast DTV supports the following MPEG decoders(Hot Key : F11):
- CyberLink PowerCinema 4
- CyberLink PowerDVD 6
- InterVideo WinDVD 7
- InterVideo WinDVD 6
- InterVideo WinDVD 5
PS: CyberLink PowerDVD 5 is not supported
Please post the log file:
C:\Program Files\WinFast\WFDTV\DVBT_LOG.TXT
The error message is wrong, There are many errors before the "Can not load Decoder".
Are you running the Emerald ?
The "ehrecvr.exe" will be re-starting automatically before it was killed by WFWIZ.EXE.
The best way to run WinFast DTV in MCE2005 is:
Step 1 : Run "net stop ehrecvr" to stop the ehrecvr
Step 2 : Run WinFast DTV
Step 3 : Run "net start ehrecvr" to re-start the ehrecvr
BTW, this ("net stop ehrecvr" and "net start ehrecvr") "will be done in the newest WinFast DTV on Sep..
Krypto1
  Do you mean the Winfast DTV program errors when you using XPMCE or XP ????
The card runs fine in MCE, but it won't see SBS for some reason. I run it alongside a Dvico card.
In XP I can get WinDTV to run but I get a message "Fail to connect decoders". I suspect this is because the CD based installtion installs the WinDTV decoders and manually installing WinDTV doesn't install the decoders. Also WinDTV obviously can't use the nVidia decoders that are installed on the PC.
Ok that's fair enough :blink:
- I wish :P I guess if they work with most BDA applications, MCE WS etc in multiple card setup, would be good enough test.
Not according to my tests, if those are the same Conexant drivers that are used by other cards, such as the K-World, MSI, etc. Where would I be able to get these latest (4.0.112.0) drivers?
If you are using the Windows XP or Windows XP SP1, and you do not want to upgrad to SP2;
use this registry:
[HKEY_CURRENT_USER\Control Panel\International\Geo]
"Nation"="12"
[HKEY_LOCAL_MACHINE\SOFTWARE\Leadtek\DRIVER\DVBT]
"UseGeoLocation"=dword:00000001
http://myweb.hinet.net/home14/tw1965/Leadt...T_Australia.reg
It will force the driver 4.0.17.3204 to use Geo Location for bandwidth setting:
- Australia : Use 7MHz bandwidth for both VHF and UFH
- Taiwan :Use 6MHz bandwidth for both VHF and UFH
- Others : Use 7MHz bandwidth for VHF and 8MHz bandwidth for UFH
use this registry:
Windows Registry Editor Version 5.00
"Nation"="12"
I'm using XP sp2 on the PC that the card works on.
I'm using XP sp2 MCE 2005 with rollup 1 on the PC that I'm having problems with.
Step 1 : Start -> Run "net stop ehrecvr" to stop the ehrecvr
Step 3 : Start -> Run "net start ehrecvr" to re-start the ehrecvr
Hello,
I will find and post the Conexant 4.0.112.0 driver ASAP (it was deleted in my HDD, I shall find it from my many DVD+R discs):
What's new in 4.0.112.0:
- Support Oxford (Hybrid) demo board
- Support PCI Audio (Analog TV Audio go throught PCI, the Analog audio output to sound card is not necessary)
Krypto1
Your SBS problem in XPMCE could either be the "Default Bandwidth" reg fix or maybe you need a custom DLL made.
The reg info can be found on this page - it applies to a number of products
  http://www.iln.com.au/xpertdtvmods.html
Perhaps you should go to the Australian XP Media Centre site and we can help you with a custom DLL.
http://www.xpmediacentre.com.au/community/index.php?
I am refering to when I'm changing between channels. The Dvico card tunes SBS from the existing table in MCE, although it is a bit hit and miss at times and SBS is listed in my services. Its just the DTV1000T that doesn't tune SBS. It tunes everything else perfectly with no errors, unlike my other cards which sometimes miss a channel.
Krypto1
The Dvico has a "frequency translation table" in the driver. The DTV1000 does not. ( not that I'm aware of ).
Do you mean your first card is the Dvico and when you hit record you can change channels which means the second card is then working.
FYI, Reception Detail for Perth:
The SBS is in UHF, the othes are in VHF:
ABC, VHF-12, 226.5 MHz
TEN, VHF-11, 219.5 MHz
SBS, UHF-29, 536.5 MHz
Nine, VHF-8, 191.625 MHz
Seven, VHF-6, 177.5 MHz
And the signal is not come from the same site:
The Transmitter Site Location of SBS is in Bickley;
the otehrs are in Carmel.
Please visit the following link for detail:
http://www.dba.org.au/index.asp?sectionID=22
I am uploading the Rollup 2 (Emerald RC0, 29MB ), Stay tuned ...
http://myweb.hinet.net/home14/tw1965/MCE2005.Emerald-RC0.GIF
I will try to explain more clearly. The problem with the DTV1000T card on my HTPC is as follows:
It runs fine under MCE2005 if installed as previously described. However it can not be used to scan for services. If I use the Dvico to scan for services then the DTV1000T will see all the scanned services except SBS.
My understanding is that Tuner cards used under MCE use the MCE services list. Hence both cards running under MCE use the list created by scanning with the Dvico card.
I will try the work around of stopping ehrecvr when I get a chance. My impression was that the WinDTV decoder wasn't installing correctly.
When I refer to channing channel, I mean while watching TV under MCE. The DTV1000T card is significantly fater and more reliable than the Dvico and Compro card when changing channels ie the channels change fast and correctly eveery time. With the Dvico and Compro I sometimes get a blue screen saying incoreect frequency or some such message when changing channels.
TW1965
Thanks for the MCE update - very kind of you.
Do remember that when everyone finds out about your download link that hundreds of users will download it.
You might use up your traffic bandwidth on your site.
Thanks again
Krypto1
No DVB-T application can run in XPMCE without stopping the Ehome Services.
The issues about SBS or dual cards have all been discussed at the Australian XP Media Centre site. If you have read all that info then I'm sure you will be able to get it all working.
The WinFast DTV error message "Fail to load Decoder" is not means that the "Decoder decoder wasn't installing correctly".
Please post the log file (C:\Program Files\WinFast\WFDTV\DVBT_LOG.TXT) of WinFast DTV in your PC. Here is mine:
00016 Start log... v.2.0.1.34
00016 GetCaptureDevices()
00047
WinFast AVerMedia BDA DVBT Tuner
00047
m_iNumVideoDevs=1
00047 ChooseDevice(LPTSTR)
00391 BuildGraph()
00391 LoadNetworkProvider()
00703 CreateDVBTTuneRequest()
00734 LoadFilter(KSCATEGORY_BDA_RECEIVER_COMPONENT, &m_pCaptureDevice, m_pTunerDemodDevice, TRUE)
00750 LoadDemux(**)
00828 BuildAVSegment(),m_Decoder_Type=1
00828 GetTeeSplitterOrCCDecoder(TRUE)
00828 Enum: Tee/Sink-to-Sink Converter
00906 LoadFilter(KSCATEGORY_BDA_TRANSPORT_INFORMATION, &m_pTIF, m_pDemux, TRUE)
01109 CoCreateInstance(CLSID_PsiParser)
01219 QueryInterface <IWFMpeg2PsiParser> m_pPSIAPI
02891 LoadAudioVideoDecoder(m_pFg, &m_pAudioDecoder, &m_pVideoDecoder, m_Decoder_Type)
03797 ChooseVideoRenderer()
04250 SetVideoStretch()
04250 QueryInterface <IVideoWindow> m_pVideoWindow
04297 ChooseAudioRenderer()
04535 CreateMPEG2DemuxPin()
Hello,
That would be good, thanks :blink:
I ran stop ehrecvr and got a different message "fail to load video renderer"
Here is the log file. Thanks for all your help.
00000 Start log... v.2.0.1.34
00000 GetCaptureDevices()
00005
WinFast DTV1000T BDA DVB-T Tuner/Demod (Thomson DTT7579)
00005
FusionHDTV, BDA Tuner
00005
m_iNumVideoDevs=2
00005 ChooseDevice(LPTSTR)
00010 BuildGraph()
00010 LoadNetworkProvider()
00017 CreateDVBTTuneRequest()
00019 LoadFilter(KSCATEGORY_BDA_RECEIVER_COMPONENT, &m_pCaptureDevice, m_pTunerDemodDevice, TRUE)
00023 LoadDemux(**)
00024 BuildAVSegment(),m_Decoder_Type=3
00024 GetTeeSplitterOrCCDecoder(TRUE)
00025 Enum: Tee/Sink-to-Sink Converter
00039 LoadFilter(KSCATEGORY_BDA_TRANSPORT_INFORMATION, &m_pTIF, m_pDemux, TRUE)
00042 CoCreateInstance(CLSID_PsiParser)
00043 QueryInterface <IWFMpeg2PsiParser> m_pPSIAPI
00069 LoadAudioVideoDecoder(m_pFg, &m_pAudioDecoder, &m_pVideoDecoder, m_Decoder_Type)
00076 ChooseVideoRenderer()
00276 !! Fail to ChooseVideoRenderer()=80040217
00276 !! BuildAVSegment()=80040217
00005
00005
00005
m_iNumVideoDevs=2
00010 BuildGraph()
00023 LoadDemux(**)
Press F11 and then change the Renderer from "Overlay" to "VMR" or "VMR9"
