SkyAudio Posted August 2, 2013 Posted August 2, 2013 Musical Fidelity AMS 35i Pure Class A dual-mono power stages Int Amp. LEss than 2 months old. Local set with original invoice. Remote Controller still in bubble wrap. Selling for S$8,900. AMS35i - Design and Build The AMS35i is a true high-end integrated amplifier; a pure Class A design with remarkable technical performance, exceptional musicality and premium build. Its pre-amplifier section has discrete power supplies with separate transformer windings. The dual-mono power amp element is equally isolated; in essence, the AMS35i is an optimised pre/power design that happens to sit in the same box. The AMS35i’s power-amp circuitry is directly descended from the design used in our flagship TITAN and the dedicated AMS50 and AMS100 power amps. This results in an astonishing technical performance from an integrated amp, even at very high frequencies. The AMS35i has less than 0.01% distortion from 10Hz to 50Hz. Its signal-to-noise ratio, frequency response and power delivery are equally outstanding. The AMS35i delivers 35 Watts of pure Class A power per channel into 8 Ohms – enough to drive most speakers and fill all but the largest of rooms. It offers both balanced and line-level connectivity, and has pre-amp outputs that allow for bi-amping. It has two pairs of speaker outputs, too. AMS35i - Specifications Performance Power output: 35 Watts per channel into 8 Ohms (15.5 dBW) THD(+ noise): <0.014% typical Signal to Noise Ratio: >96dB Frequency Response: +0, –0.1dB, 10Hz to 20kHz Inputs 4x RCA Phono Line Level 1x Line level XLR Balanced General Dimensions - WxHxD (mm): 483 x 148 x 475 Weight (unpacked / packed): 28.3 kg / 33 kg REVIEW http://www.hi-fiworld.co.uk/amplifiers/47-transistor/208-musical-fidelity-ams-35i.html http://www.soundstagehifi.com/index.php?option=com_content&view=article&id=95:musical-fidelity-ams35i-integrated-amplifier&catid=55&Itemid=4 Please SMS nine7270672 for any enquiry and appointment to view and listen. Thanks & Best Regards Steve Sky Audio Blk 621 Bukit Batok Central #20-516 Singapore 650621 Tel: 6762 5890
