Discover the Elektra Theatre 7 at Len Wallis Audio in Lane Cove | SH20700
Legendary Australian multi‑channel power amplifier delivering high current, robust output and a warm, musical presentation.
Key Features
High‑Power 7‑Channel Amplification: 185 watts RMS per channel into 8 ohms with all channels driven.
Warm, Musical Character: Renowned for a richer, more engaging sound compared to typical AV receivers.
High Current Delivery: Strong output into 6 and 4 ohm loads for demanding speaker systems.
Wide Frequency Bandwidth: Extended response from 3 Hz to 250 kHz ensures openness and detail.
Robust Australian Build: Solid construction designed for long‑term performance and reliability.
The Elektra Theatre 7 Power Amplifier is a highly respected Australian‑designed multi‑channel amplifier, widely regarded for its ability to deliver both power and musicality in home theatre systems. As the predecessor to the later HD2 model, it retains a strong following among enthusiasts seeking high‑quality amplification without the compromises of mass‑market AV receivers.
This pre‑owned unit is in good working order and finished in black. It shows some cosmetic scuffs and marks consistent with use, but performs as intended. Please note that no accessories or original packaging are included.
Visit our Lane Cove showroom to experience the performance of the Theatre 7.
Technical Specifications
Amplifier Type: 7‑channel power amplifier
Power Output: 185 W RMS per channel into 8 Ω (all channels driven)
Power Output (6 Ω): 220 W RMS per channel
Dynamic Power: 200 W (8 Ω), 400 W (4 Ω)
Total Harmonic Distortion: 0.005%
Signal‑to‑Noise Ratio: 111 dB
Frequency Response: 3 Hz – 250 kHz (+0, −3 dB)
Inputs: RCA (unbalanced)
Weight: 25 kg
Condition: Good working order; visible cosmetic marks, no accessories or original packaging
The item represented is being sold by a Commercial Member. This means they have certain legal requirements when selling new and second-hand goods, and must provide a statuatory warranty under Consumer Law applicable to their location. These requirements may differ depending on their region, so discuss these entitlements with the Seller prior to purchase.
