  For Sale Audio Research REF160S Power Amplifier
AUD $34,990
2 Images
This add will expire in 7 days and 12 hours
Ad Details
Price
AUD $34,990
RRP/MSRP
AUD $49,995
Product Type
Power Amplifier
Model Name
REF160S
Brand New
Payment Method
PAYPAL, DIRECT TRANSFER, CASH, CREDIT CARD IN STORE, Afterpay, ZipPay
Region/State
(WA) Western Australia/Australia
Suburb or Town
Midland
Original Receipt Available
 Yes
Shipping & Pickup Options
Shipping:  Available
Pickup: Available
Auditioning
No
Reason for Selling
Did not fit in clients cabinet
Further Information
BRAND NEW NEVER PLUGGED IN
FULL 5 YEAR MANUFACTURERS WARRANTY
FULL DETAILS HERE  https://audioresearch.com/new_website/audio-research-reference-160s-stereo-power-amplifier/
TECHNICAL SPECIFICATIONS
Power Output
140 watts continuous from 20Hz to 20kHz. 1kHz total harmonic distortion typically 1% at 140 watts, below 0.04% at 1 watt. (Note that actual power output is dependent upon both line voltage and “condition” i.e.: if power line has high distortion, maximum power will be affected adversely, although from a listening standpoint this is not critical)
Power Bandwidth
(-3dB Points) 5Hz to 70kHz
Frequency Response
(-3dB points at 1 watt) 0.5Hz to 110kHz
Input Sensitivity
2.4V RMS Balanced for rated output. (25.5 dB gain into 8 ohms)
Input Impedance
300k ohms Balanced; 100k ohms Single-ended
Output Polarity
Non-inverting. Balanced input pin 2+ (IEC-268)
Output Taps
4, 8, 16 ohms
Output Regulation
Approximately 0.6dB 16 OHM LOAD TO OPEN CIRCUIT (Damping factor approximately 14)
Overall Negative Feedback
14dB
Slew Rate
13 volts/microsecond
Rise Time
2.0 microseconds
Power Requirements
105-130VAC 60Hz (210-250VAC 50Hz) 875 watts at rated output, 700 watts in Triode mode, 500 watts at “idle”, 3.6 watts off
Tubes Required
4 matched pair KT150 (Power output V1-4); 4 6H30 (Gain stage V5 and V6)
Dimensions
Width  19.0” (48.26 cm)
Height 10.25” (26 cm)
Depth  21.5” (54,61 cm)
With Handles and Connectors: 24” (60.96 cm)
Weight
100lbs
ELECTRICAL DISCLAIMER
View All Ads Combine & Save - Other Ads from WC HiFi Midland
Kirby66
WOW !!! you'd think a person would check the size when dropping that kind of coin ... or get another cabinet ?!?! leaves a huge bargain for someone else
