Valerion VisionMaster Pro 2 Laser Projector Review
John Archer reckons this affordable new cube is so much more than just another lifestyle projector…
If you haven’t heard of Valerion before, then don’t worry, as you’re not alone. The brand is actually a premium offshoot of AWOL Vision rather than a completely stand-alone entity, and has only really been going as a serious force in the projector world since the latter half of 2024. In other words, the name is still so new by AV standards that you can practically still smell the polish.
If the VisionMaster Pro 2 projector under scrutiny here is anything to go by, though, Valerion’s journey to household name status could be deservedly swift. Its bid to capture hearts and minds starts with a uniquely eye-catching, roughly cubic design that the company claims is capable of being everything from a living room-friendly home theatre projector to a premium gaming projector and a high-quality home entertainment hub.
That ambition rests on a 4K-resolution DLP optical system illuminated by an RGB laser lighting array rated at 3,000 ISO Lumens, alongside a claimed 110% coverage of the BT.2020 colour gamut. That’s an ambitious figure, exceeding the DCI-P3 gamut used in most HDR mastering. If realised in practice, it would provide significant colour headroom compared with typical projectors in this class.
As with most consumer DLP projectors, 4K resolution is achieved via Texas Instruments’ XPR pixel-shifting technology rather than a native 3,840 x 2,160 DLP chip. Contrast is rated at 15,000:1 when using the Enhanced Black Level system, while HDR support includes Dolby Vision and HDR10+, alongside HDR10 and HLG.
The VisionMaster Pro 2 carries IMAX Enhanced certification and includes a Filmmaker Mode preset. Google TV is built in, with access to major streaming platforms including Netflix, Prime Video, Disney+, Apple TV and YouTube. In the UK, Channel 4, Channel 5 and ITV services are supported, though BBC iPlayer is absent.
Gamers are catered for with support for up to 240Hz at 1080p, delivering input lag as low as 4ms. At 4K/60Hz, lag measures 15ms. Crosshair overlay support and 21:9 and 32:9 aspect ratio compatibility are also included. However, HDR support drops at higher frame rates and variable refresh rate is not supported.
Up Close
The roughly cubic design is elevated by a distinctive silver-edged ribbed finish wrapping around the sides and top, contrasting with a smooth grey fascia. Build quality is excellent, though the unit’s weight and ribbed edges make it slightly awkward to carry.
The all-glass lens supports a generous 0.9–1.5:1 optical zoom range and optical vertical shift. An AI-driven automatic set-up system handles autofocus, keystone correction, screen alignment and object avoidance impressively well. Connectivity includes dual HDMI inputs, two USB ports (3.0 and 2.0), optical digital audio output, Ethernet, Wi-Fi and Bluetooth 5.2.
Getting Going
Configuration is refreshingly straightforward. The automatic alignment system performs accurately provided the screen has a defined border. Manual controls remain available, but are rarely required.
However, achieving best performance requires firmware updates. The December 2025 P1215 update introduces improved HDR tone mapping, anamorphic lens support and Dolby Vision Dark luminance adjustment. A separate Texas Instruments firmware update, applied via USB, significantly reduces the DLP rainbow effect. While described as optional, its impact makes it strongly recommended.
Picture Performance
With updates applied, the VisionMaster Pro 2 delivers impressively accomplished images for its price point. The rainbow effect is significantly reduced, though not entirely eliminated.
Measured in Filmmaker Mode using professional calibration tools, HDR10 performance produces DeltaE 2000 averages of 3.94 (ColorChecker), 5.25 (P3 sweep) and 5.09 (BT.2020 sweep). SDR measurements are even stronger, with DeltaE averages of 2.6 or below.
While independent testing did not confirm 110% BT.2020 coverage, the projector consistently achieved over 96%, alongside 139% of DCI-P3. Brightness reached 71 foot-lamberts in HDR Filmmaker Mode. Native SDR contrast measured 1,418:1, increasing to 7,800:1 with Enhanced Black Level engaged.
In real-world viewing, colour performance is a standout strength. HDR and SDR images balance vibrancy and subtlety impressively, maintaining tonal integrity even in demanding Dolby Vision material. Black levels are respectable rather than class-leading, though activating Enhanced Black Level on its Low setting substantially improves depth and perceived contrast without destabilising highlights.
Detail is crisp, falling only slightly short of premium native 4K projectors from Sony and JVC. Motion handling is strong, with the Film processing mode smoothing judder without obvious artefacts. The Clear motion preset, however, is best avoided due to visible processing side effects.
HDR Standard and HDR Cinema modes provide brighter, more vivid performance for ambient light environments, retaining balance while increasing impact. The projector adapts convincingly across varied room conditions — a key strength in this category.
Audio Performance
The integrated 2x 12W speaker system exceeds typical projector expectations, delivering solid bass presence and respectable scale. Dolby Atmos material generates a modest but convincing sense of spatial spread, though forward projection remains limited and high frequencies can sound slightly harsh.
While not a replacement for a dedicated audio system, it comfortably outperforms most built-in projector audio solutions.
The Verdict
Valerion may be a relatively new name, but the VisionMaster Pro 2 feels assured and mature. It blends strong measured accuracy, impressive colour performance and excellent flexibility with user-friendly setup and meaningful gaming credentials.
Careful configuration — particularly firmware updates and black level settings — is essential. Once optimised, however, this compact and competitively priced projector proves capable across a wide range of content and environments. It is, genuinely, more than just another lifestyle projector.
For more information visit Valerion
John Archer
I’ve spent the past 25 years writing about the world of home entertainment technology. In that time I’m fairly confident that I’ve reviewed more TVs and projectors than any other individual on the planet, as well as experiencing first-hand the rise and fall of all manner of great and not so great home entertainment technologies.
Posted in: Applause Awards | 2026 | Visual | Projectors | Home Theatre | Visual
Trending
