Fyne Audio has added a new Theatre Monitor range to its home theatre line-up, aimed squarely at premium residential cinema and custom installation. Built around the company’s IsoFlare point-source driver tech, the series promises high output with controlled dispersion for immersive rooms.
The lineup has three models: F708TM, an 8-inch (200mm) IsoFlare Theatre Monitor (117dB peak); F712TM, a 12-inch (300mm) IsoFlare Theatre Monitor (126dB peak); and F7-12TM Sub, a 12-inch (300mm) passive subwoofer designed to match the 12-inch monitor's (126dB peak).
The speakers were unveiled at Smart Home Expo 2026 in Mumbai, with India slated to receive the first commercial release in Q2 2026, followed by other regions.
Dedicated to Cinema
Designed to sit behind fabric walls and acoustically transparent screens, the monitors are intended to deliver high SPL with clear dialogue and even coverage across multiple seats.
IsoFlare places the high-frequency unit at the centre of the mid/bass driver, aiming for point-source coherence and consistent dispersion — a key ingredient for modern multi-channel cinema set-ups.
All three models use rigid cabinets finished in low-sheen black, with multiple threaded fixing points and rear cable management aimed at keeping the installation neat and visually discreet.
Installer-friendly mounting provisions include multiple M10 flying points for suspension, plus rear VESA-compatible 200×200 M8 inserts for wall mounting, with portrait or landscape orientation supported.
Fyne also highlights flush-fit cable routing and cabinet geometry developed with professional installers in mind.
Naturally, the Fyne Audio Theatre Monitor range is designed and manufactured in Scotland, with production handled at its Glasgow facility.
Shipping is expected to trade in July/August: F708TM £950 | US$1,300 | €1,100; F712TM £1,700 | US$2,300 | €1,950; F7-12TM Sub £1,250 | US$1,700 | €1,450.
For more information visit Fyne Audio
Posted in: Home Theatre
