walpataca Posted June 23, 2015 Posted June 23, 2015 Item: Auralic Aries Streamer (Dual Femto clocks/ultra-low noise linear power supply model!)Location: SydneyPrice: $1,850 ONOItem Condition: MintReason for selling: Reducing goodsPayment Method: Pickup - Cash, Bank Transfer Less than one year old, bought new from the official Australia distributor at full retail price ($ 2,299). It is in mint condition with no marks. Comes with all original packaging and boxes. This is similar to a Logitech Touch – but pushed out to the max with much higher sound quality and features. Works with WiFi, Ethernet and USB 2.0 inputs. Spdif, AES, USB outputs to be used in conjunction with a DAC. The USB output can deliver PCM from 44.1-384kHz at 16, 24 and 32-bit resolutions as well as DSD64 and 128 into a compatible USB DAC. The other digital outputs are limited to 192kHz/24-bit according to the S/PDIF standard into a DAC Compatible with AAC, AIFF, ALAC, APE, DIFF, DSF, FLAC, MP3, OGG, WAV, WV and WMA files. You can also attach a USB disk drive to it and it will scan your music and play the files directly. Alternatively, you can point the Aries to a NAS/Computer (running a UPNP server) and it will ‘pull’ music files to play. You can use the free ‘Lumin’ or ‘DS lighting’ Apps on the iPad to control what music you play. Go online and read the many glowing reviews. This is the more expensive version which comes dual Femto clocks as well an ultra-low noise linear power supply; this is one of the best Streamers you can buy.
fire2368 Posted June 24, 2015 Posted June 24, 2015 Damn, I really wanted this but I just bought an amp last night. GLWTS
wolster Posted August 7, 2015 Posted August 7, 2015 This item has been relisted, withdrawn from sale or sold elsewhere.
