SumonKabir Posted June 16, 2014 Posted June 16, 2014 (edited) I am looking to borrow a spare SUT locally until my Hashimoto HM7 arrives. Until then I can stop being itchy to try my Dynavector 23RS MK2. Someone must have a spare SUT suitable for this cart lying around not being used. Edited June 16, 2014 by SumonKabir
rocky500 Posted June 16, 2014 Posted June 16, 2014 (edited) Would a iPhono be any use to you. I have here you could borrow. It seems to have lots of adjustments. http://www.enjoythemusic.com/magazine/equipment/0313/ifi_audio_iphono.htm I also have a Tom Evans phono stage but I am waiting on an email from Tom about details of a MK2 upgrade. Quote from a recent email from him: "it can be upgraded to the latest Mk 2 spec for a massive leap in performance. Regards Tom." Edited June 16, 2014 by rocky500
SumonKabir Posted June 16, 2014 Author Posted June 16, 2014 Hi Tom, Sweet. anything will do right now to stop me getting mad. Can I pickup today? tonight? Thanks. Kabir Would a iPhono be any use to you. I have here you could borrow. It seems to have lots of adjustments. http://www.enjoythemusic.com/magazine/equipment/0313/ifi_audio_iphono.htm I also have a Tom Evans phono stage but I am waiting on an email from Tom about details of a MK2 upgrade. Quote from a recent email from him: "it can be upgraded to the latest Mk 2 spec for a massive leap in performance. Regards Tom."
SumonKabir Posted June 16, 2014 Author Posted June 16, 2014 Still looking for one. Prefer SUT. For some reason Rob's iPhono making lot of noise when using with my MM input. Tried all sort of troubleshooting and no luck.
blackangus Posted June 16, 2014 Posted June 16, 2014 Still looking for one. Prefer SUT. For some reason Rob's iPhono making lot of noise when using with my MM input. Tried all sort of troubleshooting and no luck.Your post reads as though you have set it up incorrectly. The iphono is a standalone unit that you would plug directly into a line input of your pre or integrated. my apologies if I have misunderstoodbtw I always found mine dead quiet and the dip switches underneath will allow you to set loading and gain for your dynavector 2
SumonKabir Posted June 16, 2014 Author Posted June 16, 2014 Your post reads as though you have set it up incorrectly. The iphono is a standalone unit that you would plug directly into a line input of your pre or integrated. my apologies if I have misunderstood btw I always found mine dead quiet and the dip switches underneath will allow you to set loading and gain for your dynavector You are absolutely correct. My bad. I have now connected the unit directly to line stage and it is all good. May be I was too excited.
