Very good single ended class A dual parallel EL34 tube amp for sale.
Made even better with Paper In Oil bypass capacitors on power supply and signal.
Will sell for $500 ONO.
Selling due to:  Too many amps and need the $$$
Condtion: Excellent 7/10
Tubes: 6N8P (897) then two 6J4P in the middle.  The large ones in the back are two rectifier tubes 5Z3P
More specs:
Input Impedance:  100Kohm
Output Impedance: 4ohm    8ohm
Input Sensitivity: 500--2000mV
Total Hamonic  Distortion: less than 1%(1KHz)
Frequeney responses: 20Hz-30KHz+/-1dB
Maximum output:  25W×2(8 ohm  Standard)     20W×2(8ohm   Triode)
Signal to Noise Ratio: 86dB
Input Jacks:    4 groups
Output Jacks: 2 groups
Supply Votage:AC100V-AC240V  available 60Hz/50Hz
Size:  435mm(Width ) ,180mm(Height ) ,340mm(Depth )
Net Weight:  22kg
post-146798-0-00053000-1402820275_thumb.
Edited by markergo
More specs:
Net Weight:  22kg
