Hi guys
Tomorrow I'm off buy the bits I need to build an Intel NUC Roon Server and want to power it with an LPS.
I'm wondering if anyone has any suggestions, I don't want to get crazy on price but also not bargain basement territory either.
I'm currently using a Teddy Pardo to power my EtherREGEN. I haven't been in the LPS requirement zone for about 5 years so I'm a bit out of touch with what's out there.
TIA to all
Dave
13 hours ago, Davey Willo said:
Hi guys
I would think you can't go wrong with an LPS from Clay Gieseler, here on SNA.
(Note: he's currently on holiday in Japan .... so he may not be able to respond quickly, if you contact him.)
@andyr 👍
Hi Dave,
my 19v 4A Kraftwerk II would be ideal to power a Intel NUC Roon Server.
Cost is $700 including delivery & the correct DC cable to suit the NUC.
Should be in stock but I currently in Japan so I can check when I return to Australia on the 8th of May.
Hi Dave
I built my own Nuc Roon Server and can testify that Clay's 19v Kraftwerk II is brilliant, you won't be disappointed if you were to proceed.
I have had about 4 or 5 of Clays products and they all improved my system, plus Clay is great to deal with.
Barry
Thanks guys
I'm still to buy the parts, my local PLE are useless, I'm going to have to use PC Case Gear again, I just hate not having local bricks and mortar to walk into if a part is faulty or fails.
I have filled out my cart, I just have to pull the trigger.
https://www.pccasegear.com/sc/j4uDfF
I'll give you a call Clay.
Dave
1 hour ago, Keith_W said:
Since you are in Perth, I suggest you get in touch with Chanh - @AccMagi7s
Hey Dave, if you're in the northern part of the river, come and take one of my servers with a built-in linear PSU for a home trial.
Edited by AccMagi7s
Wow what a wonderful offer, Chanh. I will take you up on that if I may.
I'm NOR, very NOR actually, Jindalee/Butler area, where are you located?
Cheers again 🙂
Dave
Edited by Davey Willo
Hi Dave,
No problem! I'm in Morley, which is about 30 km your way. Take the server home and log in to your Roon account; everything should be fine. Do you have any plans for a dedicated USB card port? Having a dedicated USB card will significantly improve sound quality, unless you already have a dedicated renderer.
Lastly, not sure if I want to post my contact number in the public forum. Perhaps edit and remove it to be safe?
18 hours ago, AccMagi7s said:
Hi Dave,
Sorry Chanh, I'm not sure that I understand the question, by renderer do you mean my SOtM SMS 200 Ultra Neo? And are you saying that I should install a dedicated USB card into the NUC for better SQ?
I am currently feeding over wifi from my laptop which has the Roon core installed on it.... Not a good way I know that which is why I'm going to a dedicated server hardwired into the EtherREGEN.
Are you ok with DMing me your phone number and I'll call you to set up a time to come visit.
Thanks again Chanh, very impressed and grateful of your generosity.
Regards
Dave
