I bought a Wiim Ultra to use with Qobuz in to Geiseler Reinigen and Kompakt 2
I set it up correctly selected usb output did firmware update and waited for the magic to begin.It works on the Wiim app screen and the Ultra screen but no sound through speakers.
I need help to isolate what the issue is
so any help would be appreciated.
Have you taken any steps yet?
From simple to more involved:
is there a volume setting at zero anywhere in your devices (digital or analogue)?
have you rebooted the device?
is there sound using any other output than USB?
is there sound via headphone directly from the wiim?
is there sound going direct from wiim to amp via RCA?
have you started process of elimination (disconnecting  the Reinigen and / or Kompakt)?
Edited by Steff
Hi Steff,It’s wierd because some music plays but the radio stations play on the screen but no sound.It has to be a setting somewhere.I tried line out direct to preamp but had the same issue.
My old MacBook works fine configured the same way.
I read in the manual that there are two ways for volume control—which do you use?
Screenshot2025-04-15at13_00_20.png.88e5b4e50217f563828c87635f738644.pngFor the first method, I read online that the fixed volume output is NOT identical for all outputs.
The some sound but not radio does suggest a setting somewhere...
also (you have likely looked at this already):
Ok well done! It sounds like either the USB can't handle the 24/192 or one of the Gieseler devices? Would be interesting to isolate the cause. Perhaps @Gieseler Audio could help with a comment?
1 hour ago, Mickeydamouse said:
Hi Steff, I changed the resolution to 24/96 from 24/192 and that seems to have fixed the issue.Once again thanks for your help
Which version of Kompakt 2 do you have? If it is the glorious-sounding TDA1541A version, it is limited to 24/96 as per Clay's website:  Kompakt II DAC | gieseler
Edited by pete_mac
Hi @Mickeydamouse, good to see you've found your answer ... I had a similar 'discovery' when I changed from a Gieseler M19D Fein II to a Kompakt II TDA1541A. It took me a few days to work it out but once I did I was able to re-download from Qobuz albums at 96k which I had previously downloaded at higher res. As I had previously downloaded them there was no charge - yay for Qobuz !!
If you're streaming only this is of no matter, but if you are paying for and storing files on a HD as I do with favourite albums, I will often download the highest resolution file (sometimes a dollar or two more expensive) and then download a 96K version for free to use in my current set up - who knows what DAC I may be using in the future ... It would have to be something pretty bloody special to displace my Kompakt II
  • Like 6
Using Roon it’s a simple matter of limiting sample rate to 96kHz in the Streamer setup menu. Also have a preset in Muse to turn of all DSP processing.
