33 minutes ago, Athanasios said:
I am a collector of vinyl records and turntables. I have 15, among them included sl1200, slq2-3, sl150, onkyo cp1057f, all of then direct drives, thorens ,pioneer, pink, rega, jvc, akai, belt drives, lenco ,dual's perpettum ebner, elac, idler drives,  and others, and i know very well which is sounding better because i use them every week so they work for mechanical parts. I am not a rega fan but i do know that with the same cartridge before the problem start, was better of any direct drive i own. By the way with the pulley trimming i manage to get the rpm at 33,39-33,42 so i am not touching it any more. Leave it as is now. Thank you all for your help , appreciate it.
From the horses mouth , Rega sounds best!  Best shut up from the peanut galleries. 🙂🙂
Yassou, @Athanasios,
Re. Rega's 24v (Premotec) AC motors - I run 2 of them on my 'SkeletaLinn'.  The motor speed controller which I use is programmable (when connected to my laptop); one of the parameters I can change is the Hz fed to the motors (which, as you know, changes the rotational speed).  Does Rega offer a 'smart' motor speed controller which allows you to play with the Hz?
Nitpick alert:   The parameter you control is called "frequency".  You do not play with the Hz.  That is only the unit you use to measure it.
Sorry, but loose terminology bugs me 🙂   Another big one is people buying and selling kilowatts.  No, they buy and sell kilowatt-hours. 🤪
True!  👍
Absolooutely!  :smile:  Also - 'there' instead of "they're".
  • Thanks 1
People eating calories...... Just a measurement.
May as well eat a kilometre.
