WiiM Custom Installation Series with Taga Harmony at CEDIA - Supported Control Platforms Control4, RTI, URC, Josh.ai...
The WiiM CI Range is on display and featured at the CEDIA Tech + Business Summit in Newcastle, NSW, from October 22-24, 2024 with Audacity Australia.
If you are using Control Automation software in your home the learn about the New WiiM CI MOD range, Hi-Res Audio Streamer and Amp, designed for Custom Integration. Supported Control Platforms Control4, RTI, URC, Josh.ai, Rack Mountable, Supports Tidal Connect, Spotify Connect, Chromecast Audio, Alexa cast, HDMI ARC for TV (Amp only) and more...
You Might have caught the range and heard the Taga Harmony Nostalgic Loudspeakers or the In-Ceiling, In-Wall, Outdoor-Indoor On-Wall Speakers at the StereoNET Hi-Fi Show in Melbourne
If your considering In-ceiling, In-Wall or On-Wall, for your outdoor area, lounge or any room in the house, the Combination of the WiiM AMP with the Taga Harmony Speakers produces a fantastic Hi-Fi quality listening experience, and if you are wanting Multiroom Audio its a great place to start with many installers offering complete installations for under $1,000 Per Zone with Amplifier, Cabling and Speakers. Contact us at https://audacityaustralia.com.au/ if interested and we can connect you to one of our Premium Retail partners or a Resindetial Custom Installer.
TAGA TCW 2-Way In-Ceiling Speakers
The TCW series provides superior sound performance at amazing price levels. It utilizes very rigid and strong injection-molded polymer chassis which minimizes distortion, vibrations and resonances and specialized mounting brackets that make installation very easy. The speakers can be used in audio and home theatre systems as well as in commercial applications. Super low-profile bezel, magnetically mounted grill allows the speaker to almost disappear in the room. Nowadays the expectation from modern installations speakers is not only the great sound but less visibility at the same time. With the TCW series you have both! The sound is clear, natural, dynamic and provides wide dispersion throughout a listening area, and thanks to slim bezels you are hard to see speakers mounted in the wall or ceiling!
Stereo 2-Way In-Ceiling Speaker - Sold as Pair (2 x Speaker)
Super low-profile bezel, Magnetically mounted grill, Paintable grills
TIMPC - TAGA Injection-Moulded Polymer Chassis is very rigid and strong
TEI - TAGA Easy Install mounting brackets with Blue ABS clamps
TEC – TAGA Easy Connection accept raw speaker cables up to 10AWG
Available in 5.25”, 6.5” and 8”
Learn more at Taga TCW https://www.tagaharmony.com/en/product/9138/tcw-390r
You can see the latest Video on the range below.
