georgehifi Posted September 19, 2024 Posted September 19, 2024 Do they work well?? There are many that are cheap, ($10-$50) does anyone know which does the best job???? Cheers George
georgehifi Posted September 24, 2024 Author Posted September 24, 2024 No one have any experience with these?? Cheers George
aechmea Posted September 24, 2024 Posted September 24, 2024 Inday DA4X-R https://www.inday.com/da4x.html https://www.inday.com/assets/da4x-r-manual-2019.pdf I used this 20? years ago when I ran out of inputs on a dac/pre. It has 4 coax and 4 Toslink inputs where the selected one (selected by remote) is directed to both a coax and a Toslink output. Seemed good at the time but maybe overkill for you. Good sign that they are still in business after all this time. 1
georgehifi Posted September 25, 2024 Author Posted September 25, 2024 (edited) Thanks @aechmea, ended up getting this (just the coax to optical converter) this morning, after it made an appearance on ASR in a review, and they said it was absolutely transparent. https://shorturl.at/sJpjQ https://www.ebay.com.au/itm/404013647098 Cheers George Edited September 25, 2024 by georgehifi 1
