Required Amphere Rating for On/Off Switch and Fuse
May I ask experienced members here on what amphere rating for the on/off switch and fuse need to be if I am using SMPS that outputs 156W, 24v x 6.5A?
Do I need to use On/Off switch as well as fuse rated 250V and just over 6.5A?
Thank you
Thank you
Doing a quick calc at 230 volt.   156/230 = 0.67 amperes.    That 6.5A figure is just the 24 volt DC side at 24 volts.
So. probably a 1 amp switch/fuse rated for our mains voltage.
Edited by aussievintage
Thank you very much for clear explanation.
A quick question. Is there any harm to use higher rates amp switch/fuse than 1A, say 5A fuse and 3A switch?
Yes, the fuse should be only just big enough to not blow in normal use, i.e. at turn-on (when there may be a surge) and at high loads.    The switch can be as big as you want.
Fuse should not be higher rated.
If you find that the 1A fuse blows because of initial inrush current, you should try a slow-blow fuse of the same rating.
Higher rating on the switch is fine.
No worries using a higher rated switch, but if you want the fuse to act like it's supposed to (prevent the equipment form bursting into flames) then you need to use the appropriate size fuse on the input.
Thank you all. I now got the idea what fuse rating that I need to aim at.
I might need to get 1A slow blow fuse because I tried to turn on the SMPS last night with 3A Fast blow fuse that laying around and it was working fine when turning on but blew the fuse when it was turning off.
