Guest Posted April 30, 2024 Posted April 30, 2024 Further Information: "Geek LPS/LPS4 is a linear power supply that has been designed to convert “dirty” AC power from wall outlets to “clean” DC power that is optimal for the Geek Out and Geek Pulse digital-to-analog converters (DACs). This “clean” power has very low signal noise which improves the sonic quality of music, making it sound much more natural. An additional benefit of the LPS/LPS4 is the ability to reduce the signal noise of the USB connection from the computer to the DAC, adding to the sonic improvement" This excellent linear power supply provides four outputs of 12V DC. Two are rated at 1.2amps and another two at 0.5amp. It also comes with a USB input/output which cleans up the signal on its way from the source to a DAC. This LPS4 comes with a standard mains cable and 4 output cables with the standard diameter 12V DC plug. Case has no marks or damage. Comes with original box (double boxed) so can be posted - would be about $25 inside Australia (plus insurance if you require it) https://lhlabs.freshdesk.com/support/solutions/articles/5000594845-geek-lps-lps4-linear-power-supply-setup-and-user-guide Paypal as a friend only please.
