AnthonyCollins Posted April 25, 2024 Posted April 25, 2024 Further Information: Monitor Audio BX Bronze centre channel speaker Pick up in Brunswick or Frankston. Audition possible in Frankston. May be able to deliver between Mornington and Melbourne. OFFICIAL DESCRIPTION Versatile 2-way loudspeaker perfect for on-wall applications, stereo or surround. Dual 5 1/2" C-CAM drivers and single 1" C-CAM tweeter are pitched perfectly for accurate dialogue. Acoustically matched with all other BX loudspeakers for precise surround sound imaging and consistent timbre front to back. Single bolt-through drivers. A design feature which means the driver is not fixed to the front baffle and cannot transmit vibrations and therefore colouration to the cabinet. Improved cabinet rigidity and stability. HiVe II port technology to speed the transit of air from the cabinet, resulting in more dynamic bass. High-quality terminal panels blend easy access with high-end functionality. Frequency Response 60 Hz - 30 kHz Sensitivity (1W@1M) 90 dB Nominal Impedance 8 Ohms Power Handling (RMS) 120 W Drive Unit Complement 2 x 140 mm (5 1/2") C-CAM bass mid-range driver. 1 x 25 mm (1") Gold Dome tweeter Crossover Frequency 3.2 kHz External Dimensions (H x W x D) 166 x 460 x 165 mm Weight (each) 6.18 kg
