monitor audio rs6 tweeter replacements.
Hi. I have purchased a used pair of monitor audio rs6 speakers with blown tweeters. I would like to ask any members out there if i should replace tweeters with the original ones or possibly with another brand of tweeter. Thanks in advance.
your best to find originals or replacements that meet the original specifications, otherwise your crossover won't cut the mustard
Probably best you contact a MA dealer
I looked up replacements and there is a very expensive upgrade using Morel ET448, available from Willy's Hi Fi. Perhaps if you have the original tweeters, a better option would be to have new diaphragms fitted.  I would suggest Garry Cawsey for this service, especially if you wish to have the crossovers checked out.
Thanks for all replies. Yes the morel tweeters are incredibly expensive but so much more substantial than the originals. I will have a look around for what i am after (not in a great hurry) but if i can't find anything i will try your recommendation of Mr Cawsey. Thanks.
