Further Information
Monitor Audio Silver 100 speakers.
Winner of What HiFI and Home Theatre Awards for best speakers in their category.
Pick up in Brunswick or Frankston. May be able to deliver between Mornington and Melbourne
Official details:
High output and effortless dynamics make the Silver 100 an ideal choice for medium to large rooms in two-channel stereo or multi-channel application.
Silver 100 features a massively powerful 8-inch C-CAM RST bass/mid driver rigidly fixed into a relatively compact two-way cabinet in a configuration that while relatively traditional by modern standards has a lot to offer. There is no real substitute for big drivers and their relative ease of moving air efficiently. Thus, they can deliver incredible dynamic headroom and bass extension, a feature normally reserved for floorstanding speakers.
A two-way, ported design, the Silver 100 relies on a new, 25 mm C-CAM tweeter made from the brand’s proprietary Ceramic-Coated Aluminium/Magnesium, and featuring a vented Neo magnet system, to create the cleanest possible highs. The HF unit is coupled with a specially-designed 8-inch bass/mid driver featuring a concave ‘dished’ C-CAM cone profile for incredible levels of damping and improved mid-range clarity. You’ll certainly hear the difference with Silver.
Power Handling (RMS) 120 W
Recommended Amplifier Requirements 40 – 120 W
Frequency Response (-6 dB)  40 Hz – 35 kHz
Sensitivity (1W@1M) 88 dB
Nominal Impedance 8 ohms
Maximum SPL 112 dBA (pair)
Bass Alignment Bass reflex. HiVe II port system
Crossover Frequency 2.8 kHz
Drive Unit Complement
1 x 8" C-CAM RST bass/mid driver
1 x 1" (25 mm) C-CAM Gold Dome tweeter
Cabinet Dimensions 375 x 230 x 300 mm
